Author Topic: WS View bug firmware 1.5.2 with Eurochron EFWS2900  (Read 3115 times)
Offline Hamo1234
Re: WS View bug firmware 1.5.2 with Eurochron EFWS2900
« Reply #25 on: August 16, 2020, 11:20:02 PM »
Thanks to galfert's assistance - Ive also got the app working now in Nox - make sure to use Android 7 though as I could not install the app in Android 5.
Ill report back in 2 weeks once Im in proximity of the weather station and attempt a firmware write.
« Reply #26 on: August 16, 2020, 11:29:19 PM »
Yes Nox defaults to installing Android 5. You have to use Nox's Multi-Drive and select Android 7 when creating the VM. I'll fix my Nox How To write-up.
Offline martin.breza
    • Počasí Čelákovice - Sedlčánky
« Reply #27 on: August 25, 2020, 02:34:03 AM »
Hello,
I have exactly the same problem with WIFI connection on Ventus W830 (I believe it is more or less the same PWS) since firmware upgrade to 1.5.2.
Can you please send me developer's email so that I can downgrade my PWS firmware? The situation with faulty WIFI is becoming very frustrating :(
Thank you very much in advance.
Martin
https://meteo.fotozapisnik.eu/
Offline Hamo1234
« Reply #28 on: August 25, 2020, 03:46:54 AM »
Sent you a PM.
« Reply #29 on: August 25, 2020, 04:09:28 AM »
Offline Hamo1234
« Reply #30 on: August 29, 2020, 09:30:21 PM »
Well, Im pleased to report that I used Nox on a W10 machine (running android 7 and using the settings as previously outlined) to successfully run the firmware update tool.
I have since updated the firmware to 1.5.3.3 and have maintained connectivity since (I had to re-boot the router for it to pick the weather station up again). So, fingers crossed, everything is now back on track.
Ill report back if anything changes.
Thanks to those who provided assistance (including the developer who was excellent).
