Author Topic: WH32-EP connection with HP2551-C  (Read 188 times)
Offline KD7GFL
« on: July 29, 2020, 08:21:30 PM »
Received my Ecowitt shipment today (finally) and went to work connecting sensors.  The WH31's connected with the console pretty much immediately, but for some reason the WH32-EP would not.  I tried several things and finally I got it to work by registering a new outdoor sensor, but I need to verify if that resolved the issue correctly.
Should the WH32-EP be recognized in the "T&H" field or the "T&HP" field?  I am pretty sure the "T&H" field was "Disabled" and there was an ID number (from the factory) when I initially went through the menu system.  But when I registered a new outdoor center it populated in the "T&H" field.
I am speculating this is not correct. Maybe T&H is for a WH32 and T&HP is for the WH32-EP.
CWOP: KD7GFL (AV640)
WU: KMOAUXVA6
Ambient Weather: KD7GFL
Equipment: GW1002, WH32-EP (Davis 7714), WH-31, WH-32, WH-57, HP2551-C, and an Ambient WeatherBridge.
Re: WH32-EP connection with HP2551-C
« Reply #1 on: July 29, 2020, 08:25:51 PM »
Looks correct to me.
T&H is Temperature and Humidity which is what the WH32-EP provides. In that left column it refers to the WH32 or WH32-EP.
T&HP is Temperature, Humidity and Pressure. That is the WH32B device that you keep indoor. This is very important, because without you have no barometric pressure.
« Last Edit: July 29, 2020, 08:28:43 PM by galfert »
« Reply #2 on: July 29, 2020, 08:31:23 PM »
What I recommend you do first is do both firmware updates:
- WiFi firmware update with WS View app
- Revision firmware with microSD card (SDHC type)
http://www.ecowitt.com/upfile/202007/user.bin
Offline KD7GFL
« Reply #3 on: July 29, 2020, 08:39:21 PM »
OK, I had put the WH32B to the side thinking I did not need both a WH32B and a WH32-EP, but now I realize I do.
« Last Edit: July 30, 2020, 02:10:09 AM by KD7GFL »
WU: KMOAUXVA6
Offline KD7GFL
« Reply #4 on: July 29, 2020, 08:41:10 PM »
Unless I missed something, it came with the latest and greatest firmware.
WU: KMOAUXVA6
« Reply #5 on: July 29, 2020, 08:49:52 PM »
Ok good. I don't have an HP2551-C so I don't know if those are the newest firmware versions....but okay.
Offline Mandrake
« Reply #6 on: July 30, 2020, 04:24:00 AM »
I was going to point out that you should have a TH&P sensor (for Inside) that came with the console.
That seems to be missing on your console and without you wont get pressure readings.
Retired: Old Maplin N96Y/FO Weather station
G1ZFO
Ecowitt HP2550A + WH65 (Wunderground: IGUILDFO67)
Ecowitt WH51 (x4) Soil Moisture Sensor
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WH57 Lightning Sensor (pre-prod test)
