Author Topic: Comparison of solar schemes and weather stations  (Read 16741 times)
i know i have to and 1 Guest are viewing this topic.
Offline ivano
    • http://www.supermeteo.com/stazione/ortelle/
Re: Comparison of solar schemes and weather stations
« Reply #125 on: July 06, 2021, 01:52:44 PM »
 [ You are not allowed to view attachments ]  the other morning, the usual 2/3 hours of suffering of the meteoshield pro, in no or very weak wind conditions, ](*,)
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
7)2 meteoschield pro
8)schermo lastem LSI
9) davis 7714
10)wh40
11)schermo solare RAD-14 Metspec
12)schermo solare RAD-02 Metspec
13)Meteorain 200 compact (Barani)
14)davis ventilato h24
15) Davis vp2 pro ventilata
16) GW1001 ecowitt
17) Wittboy ecowitt
template http://ortellemeteo.altervista.org/pwsd/
webcam :https://rtsp.me/embed/tRhazi3z/
Offline ivano
« Reply #126 on: July 08, 2021, 03:38:11 AM »
data of 07/07/2021 location  [ You are not allowed to view attachments ]
comparison meteoshield pro (WH32 EP) -Davis VP2 PRO (ventilated)
comparison meteoshield pro (WH32 EP) -Davis 7714(WH31 EP)
comparison meteoshield pro (WH32 EP) - Metspec RAD 02-14 (WH31 EP)
comparison meteoshield pro (WH32 EP) -Lastem (WH31 EP)
comparison meteoshield pro (WH32 EP) -WS80-VN1900(test)
comparison of anemometers
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
good day to make comparisons between the various weather systems, excellent solar radiation ventilation on average 8 KM / H in the central hours, with fairly high temperatures, almost 35 °, excellent performance of Davis 7714 with the WH31 EP inside, very well also the 2 Metspec RAD02-14 always with WH31 EP inside, the ventilated davis vp2 pro suffers as well as the Lastem, hard day also for the WS80, very good instead the VN1900 (test), I just have to wish you good view of the graphs .  =D> [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #127 on: July 10, 2021, 05:25:43 AM »
data of 09/07/2021 location [ You are not allowed to view attachments ]
comparison meteoshield pro (wh32 EP) -Davis VP2 PRO (ventilated)
comparison meteoshield pro (wh32 EP) -Davis7714(WH31 EP)
comparison meteoshield pro (wh32 EP) -RAD 02-14 (WH31 EP)
comparison meteoshield pro (wh32 EP) -Lastem WH31 EP)
comparison meteoshield pro (wh32 EP) -WS80-VN1900 (test)
good day yesterday to see differences in the various systems, average wind about 5km / h good solar radiation and high temperatures
I added some photos to the graphs to better understand what we are comparing, sometimes we take this for granted, but for those approaching this world, it may seem Arabic  =D> [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #128 on: July 13, 2021, 05:02:10 AM »
data from yesterday 12/07/2021 location [ You are not allowed to view attachments ]
comparison meteoshield pro (WH32 EP) -RAD 02-14(WH31 EP)
comparison meteoshield pro (WH32 EP) -WS80-VN1900 /test)
good day to make a comparison, these are the results  =D> [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #129 on: July 26, 2021, 04:54:21 AM »
comparisons of 25-07-2021 station [ You are not allowed to view attachments ]
comparison meteoshield pro (WH32 EP)-Davis vp2 PRO (ventilate)
comparison meteoshield pro (WH32 EP)-davis 7714 WH31 EP
comparison meteoshield pro (WH32 EP)-RAD 02-14 WH31 EP
comparison meteoshield pro (WH32 EP)-WS80-VN1900(test)
comparison meteoshield pro (WH32 EP)-Lastem WH31 EP
comparison of anemometers  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
good day to make a comparison, excellent solar radiation and weak wind, you notice the suffering in the early hours of the sun of the 2 ecowitt, with important peaks, due to the small size of the solar screen, the ventilated vp2 pro is better when the wind is weak or absent, excellent performance of the Davis 7714 with wh31 EP sensor, and also the two Metspecs have excellent performance, to be noted in the wind charts, the ws68 which goes hand in hand with the Davis vp2 pro anemometer  =D> [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #130 on: July 29, 2021, 10:54:05 AM »
data of 07/27/2021 location  [ You are not allowed to view attachments ]
Meteoschield Pro comparison (WH32 EP) -Davis VP2 PRO (ventilato)
meteoschield pro comparison (WH32 EP) -Davis 7714(WH31 EP)
meteoschield pro comparison (WH32 EP) -RAD 02-14 (WH£! EP)
meteoschield pro comparison (WH32 EP) -WS80-VN1900(test)
meteoschield pro comparison (WH32 EP) -LaSTEM WH31 EP)
hot day yesterday which recorded a maximum of 38.4 ° (2nd highest value of this year) these are the results ... amazing performance of davis 7714 with EP sensor inside good performance of 2 metspecs and ecowitt all in sum they defend themselves (better the vn1900) the lastem does what it can, for the vp2 pro ventilated, the same is always true, as long as the wind remains weak (below 5 km / h) it is unsurpassable, when the wind increases, the situation changes in the anemometric comparison to note the WS68 (ecowitt) perfectly aligned with the wind sensor of the davis vp2 pro  =D> [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #131 on: August 20, 2021, 06:39:59 AM »
comparison of 08-19-2021 station  [ You are not allowed to view attachments ]
comparison meteoshield pro (WH32 EP) -Davis 7714 (WH31 EP)
comparison meteoshield pro (WH32 EP) -RAD 02-14 (WH31 EP)
comparison meteoshield pro (WH32 EP) -WS80-VN1900 (Ecowitt)
we resume after the mid-August holidays with our comparisons, yesterday windy day, but with good solar radiation, as usual when the wind is sustained, the ventilated screens suffer a little, while the performance of the davis 7714 is to be emphasized, which with the probe sensor positioned as Davis recommends, it works great :), excellent performance even of the 2 rad 02-14 of the Metspec, even the ecowitts defend well  =D> =D>
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline hmderek
    • Meteodrenthe
« Reply #132 on: August 20, 2021, 07:21:23 AM »
Haven't read the entire topic. Do you have a theory as to why the ventilated Davis performs so differently?
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Apogee Instruments TS-100
Barani Meteoshield Pro
Davis 7714
MetSpec RAD14
Davis AirLink
Wemos D1 Mini micro controllers
https://blog.meteodrenthe.nl
https://meteodrenthe.nl
https://twitter.com/meteodrenthe
Offline ivano
« Reply #133 on: August 20, 2021, 07:30:39 AM »
hello, when the wind is above 10 km / h the ventilated starts to worsen its performance, the reason is simple, the ventilated always sucks the same amount of air both with no wind and strong wind, while for passive screens with strong wind, they work better, as more air arrives on the sensor, when the wind is absent, or weak, the speech changes the ventilated ones work well and are unsurpassed, while the passives suffer, so before installing a solar shield, it is necessary to understand the microclimate of the installation area, if it is well ventilated all year round, there is no need to install a ventilated one, but better a good passive screen,
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #134 on: August 27, 2021, 07:20:55 AM »
hi, look at how a ventilated davis vp2 behaves with the arrival of a storm, the response delay compared to a passive shielding is considerable  ](*,)
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
« Last Edit: August 27, 2021, 07:26:03 AM by ivano »
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #135 on: August 29, 2021, 11:55:03 AM »
differences in rain guest
as is well known a bit of overestimation of the vp2 pro (single chamber) the wh40 a bit underestimates this too is well known, the meteorain of Barani is doing well, a bit under ... in short, a nice mess  :-|
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline zoomx
« Reply #136 on: August 31, 2021, 04:15:33 AM »
Ivano,
can you rewrite the rain values ordered by position?
Maybe WN1900 and VP2 are close together?
Offline ivano
« Reply #137 on: August 31, 2021, 06:52:51 AM »
Ivano,
hi Zoomx, there is no pre-established order, the reference is the manual TFA without lid, yes the VN-1900 marked the same amount of rain as the VP2pro ,this comparison was made in conditions of heavy rainfall, with a rain / rate up to 205 mm / h  ;)
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #138 on: October 24, 2021, 05:41:24 AM »
summertime in summary, here are the extremes of the screens and weather stations compared, the values ​​refer to the maximum and minimum
  [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #139 on: December 02, 2021, 12:58:09 PM »
yesterday you can see the difference between a level radiation shield and the all in one stations with the small radiation shield, in certain weather conditions, in this case weak wind, absent, this does not mean that these stations are not valid , indeed ... they just have limits, look here
comparison metpro-Davis vp2 pro (ventilated)
comparison metpro-Davis 7714
comparison metpro-RAD14-RAD02
comparison metpro-LSI Lastem
comparison metpro-WS80 (Ecowitt)
comparison metpro-GW1001 (Ecowitt)
comparison metpro roof-metpro soil
all these data were processed at my weather observatory in Ortelle (Lecce) Italy, good vision  [tup]
« Last Edit: December 02, 2021, 01:00:20 PM by ivano »
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #140 on: April 18, 2022, 06:08:46 AM »
hello everyone, let's continue with the comparisons between weather stations and sun screens, I use a PDF file to be able to put all the comparisons in a single file
 [ You are not allowed to view attachments ] e
P.S why the attachment is not seen in the post? is a 764 Kb PDF file  ](*,)
« Last Edit: May 02, 2022, 07:47:38 PM by ivano »
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #141 on: May 04, 2022, 01:31:17 PM »
comparison screens / stations of 03/05/2022
good vision  [tup]
« Last Edit: May 04, 2022, 01:35:35 PM by ivano »
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
« Reply #142 on: May 04, 2022, 04:01:54 PM »
I've fixed the PDF option.. it no longer tries to display inline (which was causing the non-display issue).  It now is a link, and clicking on it will open the PDF in either the browser or Acrobat (depending on your local settings).
Offline ivano
« Reply #143 on: May 04, 2022, 04:12:08 PM »
great perfect, I figured there was a problem, thanks [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #144 on: May 05, 2022, 07:39:07 AM »
data yesterday 04/05/2022 hard and demanding day for the instruments
 [ You are not allowed to view attachments ]  [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #145 on: May 10, 2022, 03:51:25 AM »
Hello everyone, comparison data of 09/05/2022
good vision at all  :-)
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #146 on: May 12, 2022, 09:47:34 AM »
good morning everyone, data from yesterday 11/05/2022, temperatures starting to rise
good vision ;)
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #147 on: May 13, 2022, 02:19:46 PM »
good evening everyone, data from yesterday 12/05/2022
good vision at all
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #148 on: May 16, 2022, 03:43:46 AM »
good morning everyone, comparisons of 14/05/2022 and 15/05/2022, temperatures and solar radiation are starting to be interesting, close to 30 ° some stations went into difficulty
 [ You are not allowed to view attachments ]  14/05/2022
 [ You are not allowed to view attachments ]  15/05/2022
good vision at all [tup]
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #149 on: May 19, 2022, 06:02:31 AM »
good morning everyone, comparisons of yesterday 18-05-2022
day characterized by strong north wind, with good solar radiation and quite warm temperatures for the period, as already known difficult conditions for the ventilated davis vp2 pro,
in these conditions even an entry level like the gw1001 (Ecovitt) does better
1)3 gw1000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
