Author Topic: Purpleair solar setup.  (Read 815 times)
Offline JupiterJoe
  • JupiterWX.com
    • Live Jupiter, FL Weather
« on: June 22, 2020, 07:58:47 PM »
Hey guys, I'm curious if anyone's done a Purpleair sensor run on solar and battery for night. If so, what materials did you use and how is it working out?
Would something like this (panel, controller, and battery) work to run the sensor day and night?
https://www.amazon.com/dp/B07RZBVTGR/?coliid=I3BHPNSF3M6KUJ&colid=32FJR5U0RL154&psc=1&ref_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B003S1RQ2S/?coliid=I38ICVFTRU1WQY&colid=32FJR5U0RL154&psc=1&ref_=lv_ov_lig_dp_it
It doesn't seem like the sensor uses too much electricity according to the PurpleAir FAQ post about it, so I'm hoping that something like this would get the job done. "Power draw: The sensor uses 180mA (milliamp), about 1W. We have experimented with a 20Ah battery pack and it kept the sensor running for about four days."
Thank you for any advice!
« Last Edit: June 23, 2020, 02:03:31 PM by JupiterJoe »
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Purpleair solar setup.
« Reply #1 on: June 23, 2020, 03:38:01 PM »
Worth posting in the Facebook group. Adrian should be able to confirm his or not.
Sent from my GM1913 using Tapatalk
Regards Simon
Davis Vantage Pro2 Plus (6162UK) Daytime FARS WeatherLink Live AirLink PurpleAir PA-II-SD CumulusMX
Offline JupiterJoe
  • JupiterWX.com
« Reply #2 on: June 23, 2020, 04:47:49 PM »
Posted!
