Author Topic: Cumulus MX  (Read 1112 times)
Offline Jed42
Cumulus MX
« on: June 20, 2020, 04:26:27 PM »
Is there a newer guide on setting up Cumulus MX on a raspberry Pi?
Offline WSWeather
Re: Cumulus MX
« Reply #1 on: June 20, 2020, 06:32:01 PM »
Do you mean here or on the official Cumulus site?
The latter is at https://cumulus.hosiene.co.uk/viewtopic.php?f=40&t=17895
Offline Tazz 316
Re: Cumulus MX
« Reply #2 on: June 20, 2020, 07:38:03 PM »
Seems out of date as the link to install MX is dead.
CumulusMXDist3079.zip
Re: Cumulus MX
« Reply #3 on: June 21, 2020, 12:05:47 PM »
The Cumulus forum link has the discussion about each change/update to CumulusMX
The download for CumulusMX current version is always on the Cumulus Wiki at https://cumuluswiki.org/a/Software
Offline Jed42
Re: Cumulus MX
« Reply #4 on: June 21, 2020, 12:09:56 PM »
Thanks guys!! I'm working on it as I type.  :grin:
Offline Tazz 316
Re: Cumulus MX
« Reply #5 on: June 21, 2020, 12:55:11 PM »
The software download link is for windows, i was under the impression raspberry pi needed a different version, ,deb
« Last Edit: June 21, 2020, 01:00:53 PM by Tazz 316 »
Online johnd
Re: Cumulus MX
« Reply #6 on: June 21, 2020, 01:55:18 PM »
CumulusMX is multi-platform and the same download file is used everywhere. But it does require the Mono library to be present - see the detailed instructions at:
https://cumuluswiki.org/a/Cumulus_MX#To_actually_run_MX
and the section entitled 'Requirements for running on Linux and OS X' et seq.
Cambridge UK
Sorry, but I have no time to help with individual issues by email. Please post your issue in the relevant forum section here & I will comment there if I have anything useful to add.
Offline Tazz 316
Re: Cumulus MX
« Reply #7 on: June 21, 2020, 02:29:01 PM »
Does mono make it so you can run .exe?
Sorry i have not used Linux.
Online johnd
Re: Cumulus MX
« Reply #8 on: June 21, 2020, 02:52:06 PM »
In a word, yes.
CMX runs fine on a Pi but you do need to get to the stage of installing both Mono and CMX itself. Don't be too put off by the length of those instructions in the wiki - much of that text is about how to install Raspberry Pi OS in the first place. If you're using a Pi already then you have probably got to that stage and just need to dive in at the 'Add the ‘Mono’ package'  step. I don't know whether the security certificate steps are still necessary - if Mark should happen to stop by then I'm sure he'll clarify.
Cambridge UK
Offline Tazz 316
Re: Cumulus MX
« Reply #9 on: June 21, 2020, 03:38:08 PM »
Any time i try to install mono when it ask if you want to continue [Y/n] it aborts no matter what i do.  ](*,)
Online johnd
Re: Cumulus MX
« Reply #10 on: June 21, 2020, 04:08:57 PM »
Isn't that issue covered in the wiki notes? But you really would be better off asking on the Cumulus forum than on here I think.
Cambridge UK
Offline Tazz 316
Re: Cumulus MX
« Reply #11 on: June 21, 2020, 04:19:47 PM »
sudo apt install apt-transport-https dirmngr gnupg ca-certificates
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo "deb https://download.mono-project.com/repo/debian stable-raspbianbuster main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
sudo apt update
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install -y mono-complete
sudo apt autoremove
At the time of writing (18 Sep 2019), this gets Mono v6.0.0.334, which works with Buster (RaspBIAN 10). However, there have been reports of incompatabilities which require use of an older version of Mono. These may have now been fixed, or alternatively may be related to use of locales other than en_GB.UTF-8 . Please see other threads in Support Forum for discussions. NOTE: 29 Feb 2020: added -y into the line sudo apt-get install -y mono-complete . This makes the install bypass the usual 'Continue Y/n?' prompt¨which was causing strange problems for some, e.g. worked if just pressed 'Enter' to accept default 'Y', but aborted installation if pressed 'Y Enter'. Bizarre. Reboot your Raspberry Pi This would be a reasonable time to reboot your Pi:
nope they added -y but still no work.
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Cumulus MX
« Reply #12 on: June 21, 2020, 04:29:44 PM »
Running CumulusMX with Ubuntu 18.04 and latest mono without any issues here.
There is also a good startup script and Installation guide to use with Linux/raspi.
https://cumulus.hosiene.co.uk/viewtopic.php?f=40&t=17907
Sent from my GM1913 using Tapatalk
« Last Edit: June 21, 2020, 04:32:01 PM by ConligWX »
Regards Simon
