Author Topic: PWS Weather displays wrong barometric pressure value  (Read 4587 times)
Offline modean987
  • What the heck am I getting myself into?
Re: PWS Weather displays wrong barometric pressure value
« Reply #50 on: January 03, 2021, 03:41:42 PM »
The matter of choice will be made available. More to come. PWSweather / Aeries Weather are working hard at improving their services.
It is now 2021-01-03.
Yes, there is now an option in your PWSWeather Station edit screen to set pressure to MSLP, Station/Surface Pressure, or Altimeter. I have selected MSLP. There's a disclaimer there that it's still a beta option and they're working on correctly displaying the data based on your selection. I'm see that option has been available since November.
1 months later...
My GW1000 says 30.133, WU says  30.13, and PWSWeather says 29.96
Note that KFHU, my local METAR, says 30.14 on PWSWeather. I'm guessing because it is a METAR, the data is pulled from elsewhere, so they get displayed properly.
...just one of the reasons I still use WU. They, at least, display the proper pressure reading.
« Last Edit: January 03, 2021, 03:47:11 PM by modean987 »
Offline gszlag
  • ..have you calibrated your barometer today?
« Reply #51 on: May 08, 2021, 09:30:40 AM »
1 months later...
UPDATE: May 8, 2021
If you click on the gear icon on the dashboard yes, you can now choose  MSLP, Altimeter or Station [Pressure] but...if you click on MSLP you get Station Pressure (ABS). If you click on Altimeter you get REL. If you click on Station you get ??.
Here are my current readings from the Ambient WS-2000 display console:
ABS = 993.8
REL= 1016.6
Here is what the PWS Weather dashboard shows:
MLSP=993.7 (rounding?)
Altimeter= 1016.6
Station=1017.2
Interestingly ,WeeWX shows Barometer(MSLP) = 1017.2
Ambient Weather WS-2000
Ecowitt GW1000/GW1100
Ecowitt WS68: Anemometer, UV/solar
Ecowitt WH40: Rain gauge
Ecowitt WH57 Lightning sensor
Ecowitt WH32E: Outside T & H sensor
Stratus Rain Gauge (manual)
Raspberry Pi 3B+ (WeeWX/CumulusMX)
Raspberry Pi Zero 2W WeeWX/MQTT/Belchertown)
http://weather.glenns.ca (pwsdashboard - live)
http://weewx.glenns.ca
http://glenns.ca/cumulusmx2/index.htm
WU: ITEHKUMM2
PWSweather.com: MBAYWX1
AWEKAS:id=15920
WINDY: Michael's Bay, Manitoulin Island
WOW: Michael's Bay
