Author Topic: Saratoga Base-USA updated index.php maps  (Read 1737 times)
Re: Saratoga Base-USA updated index.php maps
« Reply #25 on: August 10, 2020, 02:16:01 PM »
I'd just copy wxindex.php to index.php and be done.  I never update index.php with the automated updates.  The wx...php scripts may be updated as auxiliary scripts are updated, so it's safer to have your site 'home' to index.php.
« Reply #26 on: August 10, 2020, 02:45:12 PM »
I did both, belts and suspenders.
The redirect is working fine, so I will leave it for now. I have the corrected index.php there if needed as a backup.
Offline mldenison
    • York, PA Weather
« Reply #27 on: September 13, 2020, 11:56:43 AM »
Hi Ken,
I'm not sure how/if the radar images can be resized.
Here's my site: https://www.m82a1.us/index.php#header
I'd like to make the right WU map larger to fill the frame.
Is it possible?
Windows 7 x64
Weather PC: Intel NUC
Davis Vantage Pro 2
Weather Underground: KPAYORK30
York, PA Weather (Saratoga)
York, PA Weather (Leuven)
York, PA PWS Station
« Reply #28 on: September 13, 2020, 05:32:07 PM »
In USA-regional-maps-inc.php, change
    <img src="<?php echo $rightURL?>" alt="<?php echo $rightTitle?>" title="<?php echo $rightTitle?>"
      width="320" height="240" style="margin: 0px; padding: 0px; border: none"
to adjust the width= and height= values to make the displayed image larger.
Since the NWS Radar has a different aspect ratio than the WU Satellite map, you won't be able to make them the same height, but you can make the image larger (remember to preserve aspect ratio so it doesn't get distorted).
Try using width="480" and removing the height="240" .. that seems to work.
Offline mldenison
    • York, PA Weather
« Reply #29 on: September 13, 2020, 05:59:20 PM »
Perfect.  And thanks.
Windows 7 x64
Davis Vantage Pro 2
