Author Topic: USA and Hawaii Weather Extremes  (Read 174 times)
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« on: May 31, 2020, 08:37:02 PM »
Hi All,
Don't know if this is the place to have this issue to solve for me and maybe others that might have the same issue that I have.
It seems that the data for Weather Extremes for the US and Hawaii on my Nav/Menu bar as indicated on the attachment has been stuck for a few or more days.
Where in the scripts that I could edit to make corrections or what corrections that might be needed?
Thanks for any suggestions or recommendations will be very much appreciated.
Regards,
--Stan Y.
  Maui, Hawaii
Stan Y. - KH6HHG - Maui, Hawaii --- Blitzortung ID: 993 --- FlightRadar24 ID: F-PHOG1
Weather Display 10.37s Build 70
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
1-Wire Lighting
Webcam: Axis 211
Re: USA and Hawaii Weather Extremes
« Reply #1 on: May 31, 2020, 09:03:20 PM »
Hi Stan,
You seem to be using
<!-- State Extremes Script Version 4.03e saratoga-weather.org -->
<!-- The cache life HAS NOT expired and fresh data was not written to the cache file -->
<!-- reportDate='Wednesday, March 25, 2020' -->
and that script has stopped functioning as the data source at NOAA is no longer updated.
You can use https://saratoga-weather.org/scripts-NWSmisc.php#NWSEXTR the world extremes script instead.
Offline Silversword
  • --Stan Y.
« Reply #2 on: May 31, 2020, 09:28:31 PM »
Hi Ken,
Thanks for the prompt reply and will try to figure this out and hope it works out for the fix, or where to insert this script with editing for USA and Hawaii.
Much Mahalo for all that you do to keep us going.
Regards,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
1-Wire Lighting
Webcam: Axis 211
« Reply #3 on: May 31, 2020, 09:33:32 PM »
Easy to make the change.  Customize worldextremes.php and upload.
Then in menubar.php change
include_once('usaextremes.php'); to
include_once('worldextremes.php'); and
delete (later on that page)
<!-- Weather Underground -->
<?php include_once('stateextremes.php')?> -->
and you should be good to go.  The worldextremes.php produces the $usa* and $state* variables the same as the older usaextremes.php and stateextremes.php scripts did.
Offline Silversword
  • --Stan Y.
« Reply #4 on: May 31, 2020, 09:45:24 PM »
Hi Ken,
Thanks for the tutorial, will work on it later tonight and see what happens.
Much Aloha and Mahalo,
--Stan Y.
  Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
1-Wire Lighting
Webcam: Axis 211
Offline Silversword
  • --Stan Y.
« Reply #5 on: June 01, 2020, 04:11:47 PM »
Hi Ken,
Got it working this morning.
Thanks you much again for the update and hope that this will help others as well that might have this issue.
All set and good to go for now.
Mahalo Nui, Loa,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
1-Wire Lighting
Webcam: Axis 211
