Author Topic: What is this for on Cumulus dashboard  (Read 290 times)
Offline Waimarie
« on: May 29, 2020, 06:01:54 PM »
I used Cumulus 1 for years and switched to MX when I got my new station and a GW1000.  I can't work ut though, what the bit at the bottom of the main dashboard is for.   I'm guessing for some kind of warning/alert, but I have never seen anything happen here.  Can anyone explain please?
Fine Offset WH3081 (Deceased)
Mi.Sol  WH2900C
Ecowitt GW 1000 915MHz
Ecowitt GW 1000 433MHz
Ecowitt WH31
Ecowitt WH51
Ecowitt WH57
WU: IFEATH6
WOW: 910486001
Offline mcrossley
    • Wilmslow Astro
Re: What is this for on Cumulus dashboard
« Reply #1 on: May 29, 2020, 06:34:53 PM »
Those are the alarms. As they are all greyed out you have not enabled any yet. You can enable and configure them via Settings | Alarms
Offline Waimarie
« Reply #2 on: May 29, 2020, 07:13:45 PM »
Ah.  Obvious now!  Thanks [tup]
Mi.Sol  WH2900C
Ecowitt WH31
Ecowitt WH51
Ecowitt WH57
WU: IFEATH6
WOW: 910486001
