Author Topic: Mounting pole max OD?  (Read 460 times)
Offline DennisD33
« on: May 20, 2020, 09:07:01 AM »
Question about Ambient Weather 2902B: what is the max OD pole the mounting U-bolts will accept?  A 2-inch Schedule 40 PVC pipe is 2.375 inches OD (2 3/8 inches).  Is this too big?    I bought this unit for my grandson but I want him to be the first to open the box, and I want to give him a complete package, including a pole.  Thanks in advance!
Online galfert
Re: Mounting pole max OD?
« Reply #1 on: May 22, 2020, 10:19:52 AM »
Recommended pole diameter is 1 to 2 inches according to the manual.
Online galfert
Offline DennisD33
« Reply #3 on: May 22, 2020, 10:34:27 AM »
Thanks, Galfert!  I like the galvanized pipe suggestion.  That will have an OD that will fit.  My grandson will be over the moon when he gets this unit!
I sure appreciate it!
Online galfert
« Reply #4 on: May 22, 2020, 10:44:01 AM »
The neat part of using the fence top rail pipe is that it is tapered at one end, allowing you to connect more than one section together. For the WS-2902B I recommend a height of about 15 feet. Connect top rails and bury 5 ft or cut it if you have the means. I know Home Depot will cut wood, I don't know if they would do the same for pipe. Then just put some concrete down and you are set. Be sure to use a post level.
https://www.homedepot.com/p/Empire-5-1-4-in-Polycast-Post-Level-720/100124903
You could also just use one section of rail and combine with wood fence post and then some people devise a hinge mechanism to service.
The 15 ft height is ideal for an all-in-one station. Best siting compromise for all sensors. This also allows you to reach for maintenance with an A frame ladder.
« Last Edit: May 22, 2020, 10:46:27 AM by galfert »
Offline DennisD33
« Reply #5 on: May 22, 2020, 10:57:14 AM »
Yes, thatís another good suggestion I hadnít thought about.  Weíll mount the unit at 15 feet; that will also get it at the proper height/distance ratio from nearby small trees.  And weíll insure that itís dead plumb, too.
Thanks, again, Galpert!  I know my grandson will enjoy this forum, too!
Offline Rover1822
« Reply #6 on: May 22, 2020, 11:01:16 AM »
Another thing you can use, is just EMT conduit
https://www.homedepot.com/p/1-1-2-in-x-10-ft-Electric-Metallic-Tube-EMT-Conduit-101584/100400412
Granted its only 10' but if mounting to the side of a building , works well
Ambient WS-2000
Ambient PM 2.5 (2)
Ambient WH31B
EcoWitt GW1000 (2)
Ecowitt WH57 Lightning Sensor
Web Sites: WU, Ambient Weather
Personal Sites: Weather Cam , Wind & Solar Power Data
Offline DennisD33
« Reply #7 on: May 22, 2020, 11:09:01 AM »
Thanks, Rover!  Thatís another good suggestion.  Iíll check them both out at Home Depot.
Offline Mulberry Weather Guy
  • Just another old fart.....
    • Mulberry Weather Page
Offline DennisD33
« Reply #9 on: May 22, 2020, 11:19:38 AM »
Yet another great option, Mulberry!  I like the fact that it can swing down for maintenance.  (And at Staples, of all places!)  I might bury a long 4 x 4 post as you have done, and then mount this.
Iíll mull over all these great ideas.  I do appreciate your time and expertise, everyone!
Offline Rover1822
« Reply #10 on: May 22, 2020, 11:22:19 AM »
If you go with EMT , this EMT coupling
https://www.homedepot.com/p/RACO-EMT-1-1-2-in-Set-Screw-Coupling-20-Pack-2026/203637545
I know you only need one but couldn't find a link. Will fit perfect in the U-bolts , what is nice is that you can square off the attachment to the station u-bolts , then just slide onto your pole and tighten the set screws. The one I have has 4 set screws 2 of which you wont use as the U-bolts will be there
Makes maintenance easier as the U-bolts can shift etc
Basically you are modifying the mount to be static to the pole
Ambient WS-2000
Ambient PM 2.5 (2)
Ambient WH31B
EcoWitt GW1000 (2)
Offline DennisD33
« Reply #11 on: May 22, 2020, 11:32:17 AM »
Yes, I like the idea of being able to micro-adjust with the mounting U-bolts using this connector.  Iíll certainly keep this in mind if we go the EMT route.  Thanks, Rover!
« Reply #12 on: May 22, 2020, 12:03:12 PM »
The post was a light steel tube 3" that was scrap at work. Staples was the cheapest by far on the post. Ans yes it's handy to swing down if needed. Post is anchored on concrete with 3/8 anchors, and won't move a bit. The satellite mount was my only cost, as the rest was scrap/extras from work.
