Author Topic: Read actual conditions on weatherlinkIP  (Read 173 times)
Offline josecmorales
« on: May 14, 2020, 02:04:52 PM »
Hi there.
I start this post may be in the wrong forum (Davis Instruments Weather Stations)
I have a weatherLinkIP and a meteobridge, both works fine, im installed on a RPI3 Weewx, but iy canīt works.
I guess that Weewx canīt read weatherlinkIP.
The log say this
May 14 13:37:18 raspberrypi weewx[8856] CRITICAL weewx.engine:     ****      raise weewx.WeeWxIOError(ex)
May 14 13:37:18 raspberrypi weewx[8856] CRITICAL weewx.engine:     ****  weewx.WeeWxIOError: [Errno -2] Nombre o servicio desconocido
May 14 13:37:18 raspberrypi weewx[8856] CRITICAL __main__: Unable to load driver: [Errno -2] Nombre o servicio desconocido
May 14 13:37:18 raspberrypi weewx[8856] CRITICAL __main__:     ****  Exiting...
May 14 13:37:18 raspberrypi weewx[8840]: Starting weewx weather system: weewx.
May 14 13:37:18 raspberrypi systemd[1]: Started LSB: weewx weather system.
May 14 13:39:01 raspberrypi CRON[8882]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
May 14 13:39:35 raspberrypi systemd[1]: Starting Clean php session files...
May 14 13:39:35 raspberrypi systemd[1]: phpsessionclean.service: Succeeded.
May 14 13:39:35 raspberrypi systemd[1]: Started Clean php session files.
Vantage Pro2 + UV, Airlink, Meteobridge.
@climaguayana
