Author Topic: Heathkit-ID-1290  (Read 243 times)
Offline Barry Curtis
  • "Three WX Stations and Counting...LOL!"
Heathkit-ID-1290
« on: April 30, 2020, 09:07:41 PM »
I would like to know if the wind vane and anemometer that came with the ID-1290 would work with the weather computer ID-4001.   Thanks.
Offline WA7FWF
  • Blitzortung 1196
Re: Heathkit-ID-1290
« Reply #1 on: May 04, 2020, 03:31:21 AM »
Quick answer is no, the 1290 used reed switches and magnets for direction and speed, the 4001 and 5001 use IR leds, photo-transistors and optical discs. The 4001 and 5001 are interchangeable with just a little rewiring.
Kevin
Offline Kev
« Reply #2 on: May 19, 2020, 10:05:59 PM »
Barry,
If you're handy you could build a wind boom for your ID-4001.  The main part would be constructing a housing, shafts, optical disks, and a vane. Heath now makes a replacement cup set for the anemometer.  All the interior components are readily available and could be mounted on a perf board.  As Kev says, all the boom uses are IR LEDs and photo-transistors wired in series, there's no circuitry in the wind sensors. I have the Heath schematics if you're interested and the encoder disk pattern could be scanned and sized to scale.
Heath ID-5001-C Advanced Weather Computer (1990)
Texas Weather Instruments WR-25 (1998) (Work in Progress)
