Author Topic: la mia postazione meteo  (Read 1122 times)
Offline ivano
« on: April 26, 2020, 03:23:51 PM »
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]   [ You are not allowed to view attachments ]  buonasera a tutti, ecco la mia postazione meteo, installazione sul tetto altezza 115 metri i sensori sono ecowitt gestiti dal GW1000 1WH32 inserito nel meteoshield pro , un WH31 (modificato) nel davis ed un DP50 (froggit) nell'auto costruito poi c'è la w830 della ventus dove gli ho aggiunto uno schermo aggiuntivo per schermarlo come si deve , poi abbiamo il WS68 anemometro ed il WH40 pluviometro , tra poco arriverà il wh57 sensore fulmini , e con questo è tutto  :-P
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
7)2 meteoschield pro
8)schermo lastem
9) davis 7714
10)wh40
11)schermo solare Rotronic
Re: la mia postazione meteo
« Reply #1 on: April 26, 2020, 07:41:58 PM »
Very Nice.
« Reply #2 on: April 26, 2020, 09:54:01 PM »
That Barani Meteoshield Pro is so nice. I want it but...oof!
Offline ivano
« Reply #3 on: July 21, 2020, 09:04:09 AM »
ultime modifiche e aggiunta di nuovi sensori uno schermo lastem e la ws80 della ecowitt  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]   [tup]
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
Offline Dj1225
« Reply #4 on: July 25, 2020, 01:52:25 AM »
oof?
Offline sdi89
« Reply #5 on: July 25, 2020, 03:28:17 AM »
250€  8-)
Offline Dj1225
« Reply #6 on: July 25, 2020, 01:46:11 PM »
250€  8-)
I know I know it's pretty pricey I paid $270 from the USA seller AllMeteo. I was on the fence for over a year trying to decide if I wanted to buy it. I finally said that's it I'm going to get it!! Well I've had it since June 29 and let me tell you it is well worth the investment!!! I never thought you could get accurate temperatures in direct sunlight with little wind without fan aspiration until I got the Barani Pro Shield!!
Offline sdi89
« Reply #7 on: July 25, 2020, 01:59:39 PM »
I agree. It's one of those toys we don't have to have, but once we have them we love them.
I am going to order mine next week hoping it last decades 😎
Offline Dj1225
« Reply #8 on: July 25, 2020, 02:06:52 PM »
 [tup] =D>  It definitely should the quality is amazing!! You will not regret it!!
Offline ivano
« Reply #9 on: July 25, 2020, 03:16:37 PM »
È vero costa un po', però quando ce l'hai ti accorgi che quei soldi sono spesi benissimo , tutto un altro livello , oggi come oggi  se non è il miglior schermo solare passivo in circolazione, siamo la. ;)
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
Offline Dj1225
« Reply #10 on: July 25, 2020, 03:45:17 PM »
Assolutamente!! [tup]
Offline ivano
« Reply #11 on: July 26, 2020, 07:24:28 AM »
oggi ho aggiunto un nuovo schermo auto costruito sulla postazione  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  finito il nuovo auto costruito , è solo un prototipo , se ne vale la pena , lo smonto per rifinirlo come si deve adesso è allo stato brado  vediamo che succede per qualche giorno, dentro c'è un sht35 dp50 le dimensioni sono piccole quasi quanto il lastem eccetto il primo piatto , ho voluto provare con una mezza palpebra questa volte , ma anche dentro ho cambiato qualcosa , https://www.ecowitt.net/home/index?id=9393 questo è il link per vedere in diretta i dati per chi interessa [tup]
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
Offline ivano
« Reply #12 on: August 04, 2020, 11:39:25 AM »
Nuovi arrivi  [ You are not allowed to view attachments ]   :grin: [tup]
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
Offline sdi89
« Reply #13 on: August 04, 2020, 11:44:04 AM »
I will get mine Wednesday from Barani. the sensor will take much longer though.
Offline ivano
« Reply #14 on: August 04, 2020, 11:50:06 AM »
excellent 😉 and yes the sensors take a long time to arrive, however it is a good wait 😉 you will see you will have great satisfaction with this combination of sensors  ;)
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
Offline ivano
« Reply #15 on: August 13, 2020, 06:30:45 AM »
new modification on the roof station, added the rotronic screen with a DP50 EP probe sensor inside the screen dimensions are reduced, we see that it combines to follow the data of this station live, click this link https://www.ecowitt.net/home/index?id=9393
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
Offline ivano
« Reply #16 on: August 16, 2020, 12:42:25 PM »
inserted WH31 EP in davis 7714 and installed on the ground position at 2.05 meters above the ground, next to the meteoshield pro cojn WH32 EP, it is good that the comparison begins  ;)
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
« Reply #17 on: August 16, 2020, 01:52:25 PM »
This looks like a good test. I would recommend that after this test concludes, that you swap WH32-EP with each other to make sure one WH32-EP isn't inherently better than the other.
Offline ivano
« Reply #18 on: August 16, 2020, 01:56:21 PM »
no the two sensors were previously aligned for 24h, they went together perfectly
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
« Reply #19 on: August 16, 2020, 07:08:11 PM »
Oh okay good. Sorry I missed it if you had shown that they two WH32-EP were aligned perfectly.
In any case that means that this is going to be a good test to see how the 7714 compares to the Barani Meteoshield Pro.
Maybe the next test then can be to see how much difference if you paint the 7714 inside black.
Offline ivano
« Reply #20 on: August 17, 2020, 03:56:58 AM »
yes I always do the alignment of the sensors every time I change or add something in the station, otherwise it would not make sense to compare anything;) yes painting the davis from the bottom is something that I will do sooner or later, but now let's see how it goes like this
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
Offline ivano
« Reply #21 on: August 27, 2020, 03:37:00 PM »
still changes in my position on the roof, I removed the rotronic, and I mounted the nesa sunscreen, always with a probe sensor inside the DP50 EP
let's see how it behaves ;)
1)2 gw1000
2)hp2551
3)ws80
4)ws68
5)2wh32 EP
6)3 wh31 EP
8)schermo lastem
9) davis 7714
10)wh40
