The country is in "lockdown-light", my wife and I are in the high-risk group, so no visits, 1 hour outside, yes we know the drill.
For "husband appreciation day" I got the "on-top_of_my_list" present last week, a WeatherLink-Live device.
Today I started to update the Leuven-Template and the PWS_dashboard to use the v2-API. Not yet available for (real or simulating) IP-loggers. But the WLL is "fully" supported by the v2_api =>
https://weatherlink.github.io/v2-api/v2API is somewhat more complicated compared to the old API, but well documented
https://weatherlink.github.io/v2-api/authenticationNo problem loading the latest measurement (optimistically named /current/{station-id})
"Returns current conditions data for a weather station selected by a station ID passed as a path parameter."To be honest, it is the latest measurement, up to 15 minutes old. Not really
current.
The data part for the ISS contains 68 items of which
37 are about rain (clicks/mm/in - 2 min -> 24 hours -> month year a.s.o.)
12 about wind (direction, speed 1min - 10 min)
1 temp, 1 chill, 1 thw, 1 wetbulb, 1 dew, 1 heat a.s.o.
And a dozen or so technical items for their programmers
NO high-lows ? Were did they move the high-lows? Maybe in the history: /historic/{station-id}
"Returns historic data for a weather station selected by a station ID passed as a path parameter, within a given time range."Well the history spans up to 24 hours, albeit not in the "free" plan, you need an extra paid for plan and no high/lows either.
There are no daily, monthly, yearly high-lows for your WLL.The same high-lows an average weather-station owner want to display on its website.
Davis want you to use a weather-program/computer to load the free 15 minute or , extra paid for, 1 minute data to calculate the high-lows. Or a weahter-program which can get the data from the WLL in your LAN, no need to use a v2API.
My first conclusion:
If Davis ends the current xml API a lot of station owners which are using the xml for their website, will need to find another solution as the v2API is not usable for a weather-website.
Because you can not switch to v2API when it is available for your "WeatherLink IP / Vantage Connect / WeatherLink Network Annual Subscription". In Record Types available:
https://weatherlink.github.io/v2-api/data-structure-types the line which read "High/Low Record" is changed into "
High/Low Record (deprecated)"
Wim
