Author Topic: Reliable/updated online historical weather data?  (Read 1249 times)
Offline coyotefred
« on: April 03, 2020, 06:35:59 PM »
Like many folks, I own/use a personal weather station to monitor precip, temp, etc.  I also take/report regular precip readings to CoCoRaHS.
I make/keep a pretty basic month-by-month weather log, where I compare my readings to historical climate data for my location (KBFF is the source of most of the historical data I've seen).  The main data points I'm interested in are monthly/annual average precip, and monthly/annual average temperature.
The problem I have is that the website I use to collect my weather station data (Weather Underground) only reports temp as a "monthly average temp," whereas the climate data sites I've found typically report that as monthly "average high" and "average low" temperatures, so I'm unable to compare apples to apples comparing those two sets of data.
Any ideas where I can find reliable/updated historical climate data where I can find historical monthly averages, not just "average high" and "average low"?
Thanks for your help-
Colin
WU KNEGERIN4 and CoCoRaHS NE-SB-5
« Last Edit: April 04, 2020, 01:40:39 AM by coyotefred »
Re: Reliable/updated online historical weather data?
« Reply #1 on: April 04, 2020, 12:19:11 AM »
Offline coyotefred
« Reply #2 on: April 04, 2020, 01:44:05 AM »
Thank you for this link.  From what I can see, however, the historical data ('statistics') are only from 1961-1990, and I only see average number of days of precip per month, not average amounts of precip per month...?
« Reply #3 on: April 04, 2020, 05:44:36 PM »
Hmmm... yr.no seems to have changed a lot.  For US try https://www.ncdc.noaa.gov/cdo-web/ ?
Offline coyotefred
« Reply #4 on: April 05, 2020, 12:46:06 AM »
After searching around a bit more, I was able to find this tabular data that I think will work for me:
https://www.weather.gov/cys/cliplotmntable
I can select the site I need from the pull-down.  Not sure the range/how far back the data goes to determine the 'normal,' but I think this should be good enough :)
Offline ambee
  • Weather API
  • Environment Intelligence Platform
    • Weather API -Ambee
« Reply #5 on: November 24, 2021, 02:18:19 AM »
After Searching please check Ambee. I hope this will help you.
Ambee’s weather API provides valuable actionable data and insights with a comprehensive view into real-time and accurate global weather. It gives access to real-time local weather updates for temperature, pressure, humidity, wind, cloud coverage, visibility, and dew point. Customers can get historical and real-time data from any location across the globe.
Ambee’s Weather API provides valuable actionable data and insights with a comprehensive view into real-time and accurate global weather. It gives access to real-time local weather updates for temperature, pressure, humidity, wind, cloud coverage, visibility, and dew point.  Please check https://www.getambee.com/api/weather
If you need any kind of help Please feel free to contact me.
Ambee fuses the power of thousands of on-ground sensor data and hundreds of remote imagery from satellites. Our state-of-the-art AI and ML techniques with proprietary models analyze environmental factors such as air quality, soil, micro weather, pollen, and more to help millions worldwide say safe and protect themselves. Air Quality API
