Author Topic: Virtual VP TCIP drops connection  (Read 14439 times)
0 Members and 3 Guests are viewing this topic.
Offline stevendt
Re: Virtual VP TCIP drops connection
« Reply #25 on: January 02, 2025, 08:09:22 AM »
Hi Chuck,
Trying with VPSE, in the short time that it has been running, it appears to be working - just waiting for the first hang  :-)
However, I am seeing lots of VVP Warnings as shown below - do you get these Warnings too?
regards
Dave
13:03:25:461 Warning      - VpConsole: Far too long since last loop = 6.359, last command= Get Archive Page
13:04:31:274 Warning      - VpConsole: Far too long since last loop = 6.563, last command= Get Archive Page
13:04:59:433 Warning      - VpConsole: Far too long since last loop = 6.453, last command= Get Live Sensor Data
13:05:28:927 Warning      - VpConsole: Far too long since last loop = 6.407, last command= Get Live Sensor Data
13:05:35:556 Warning      - VpConsole: Far too long since last loop = 6.281, last command= Get Archive Page
13:06:41:322 Warning      - VpConsole: Far too long since last loop = 6.485, last command= Get Archive Page
Offline andro700
  • Chuck
    • Gobles Weather Page
« Reply #26 on: January 02, 2025, 06:39:34 PM »
Yes I get those type of errors. Never have had any issues with those type of errors.
Chuck
Offline meteosa
« Reply #27 on: January 15, 2025, 05:37:33 AM »
Good morning,
I installed the new version VSPE 1.5.1.191, but I have problems with weatherlink 6.0.5 that goes into error, I use Weather Display, WeatherLink and CumuluxMX, can you tell me how you configured VSPE to make everything work?
Offline stevendt
« Reply #28 on: January 15, 2025, 06:58:00 AM »
Chuck is the VSPE expert, I am just trying out, but you need to create Virtual Serial Port pairs. I use 1/11, 2/12, 3/13 and 4/14. The low number is the serial port used in the Weather program and the high number is the VSP added in VVPro.
What "errors" are you seeing?
regards
Dave
Offline meteosa
« Reply #29 on: January 15, 2025, 07:25:20 AM »
That is? I simply use the splitter function, I tell it that the main port is COM3 and it creates the other ports com 5/6/7 for example and I start it, it doesn't work like that?
Maybe in the new version it's a little different?
Offline stevendt
« Reply #30 on: January 15, 2025, 07:34:27 AM »
"Splitting" shares a physical COM port with a number of virtual applications.
"Pairing" creates pairs of virtual ports. My PC does not even have a physical com port.
I use Virtual Vantage Pro and set up the weather programs to talk to the VSPE ports that are linked to the virtual ports referenced in the weather programs, e.g., Weatherlink is configured to use Virtual Port COM1: and VVP has a Virtual Console COM port configured for Weatherlink on COM port 11
The same configuration worked in the pervious version of VSPE too. (I have not tried the splitting mechanism.)
« Last Edit: January 15, 2025, 07:36:00 AM by stevendt »
Offline meteosa
« Reply #31 on: January 15, 2025, 07:38:19 AM »
ok, my mini-pc doesn't have a com port either but the davis station is connected via USB which then converts it to com. So should I use the "Pairing" method? Maybe that's why it doesn't work well?
Offline stevendt
« Reply #32 on: January 15, 2025, 07:46:33 AM »
I'm not an expert on this, so can't tell you what you "should" use, but I think that the pairing method is at least worth a try. I have a wireless logger, so the Davis connection to VVP is TCP/IP, but I think that it should work as well with a physical serial/USB connection to the Davis and the virtual serial ports configured as I described
Offline meteosa
« Reply #33 on: January 15, 2025, 08:04:55 AM »
ok, I'll try it like you said and I'll update you. Thanks
Offline andro700
  • Chuck
« Reply #34 on: January 15, 2025, 04:09:03 PM »
I use the default ports 6/16, 7/17, 8/18, 9/19 in VSPE. Make sure you use the lower number such as 6, 7 etc on your weather software. I am running the latest VSPE and have no issues.
Chuck
Offline meteosa
« Reply #35 on: January 16, 2025, 05:50:47 AM »
Ok, I'm having problems with WeatherLink as it does not download data if connected with VSPE, it does not update the log, in the com port settings how did you set? (like CTS, DCD, DSR parameters) while if I connect directly to the main port it downloads the data and saves it in the log. Thanks
Offline stevendt
« Reply #36 on: January 16, 2025, 05:59:52 AM »
You have not specifically mentioned it, but are you using Virtual Vantage Pro ?
Can you upload screen shots of the VVP Communications Settings screen and the VSPE status screen.
I have not made any changes to any of the Virtual COM port handshaking signals
Offline meteosa
« Reply #37 on: January 18, 2025, 05:02:13 AM »
Now everything seems to work fine, I set the lower com ports (6,7,8) instead of the higher ones, maybe that was the problem?! Thanks
