Author Topic: Interesting new charts  (Read 2456 times)
« on: March 05, 2020, 11:41:51 AM »
I haven't checked my data on Blitzortung for a while, but I just noticed a new "history" chart.
http://map.blitzortung.org/statistic_1.php?station=706&1583421415&region=3
Not sure what the "1583421415" part of the URL string is for. The "706" is my station number (for my Red), and the region is obvious. It doesn't seem to be a time/date stamp. I might integrate this into my web site, but I want to make sure that it isn't a one-off due to this 1583421415 business...
EDIT: Yup, it's changing. Eliminating it seems to still work and give the latest. http://map.blitzortung.org/statistic_1.php?station=706&region=3
I like the interference display especially.
Greg Hamel
(cross posted on sferics.us)
Offline Cutty Sark Sailor
Re: Interesting new charts
« Reply #1 on: March 06, 2020, 11:02:32 AM »
has its uses...  :thumbsup:   attached
« Last Edit: March 06, 2020, 11:10:14 AM by Cutty Sark Sailor »
« Reply #2 on: March 07, 2020, 01:13:19 PM »
Offline Storm017
« Reply #3 on: March 07, 2020, 01:43:38 PM »
The "1583421415" part of the URL string is a timestamp.  1583421415 = 03/05/2020 3:16pm (UTC)
« Reply #4 on: March 07, 2020, 03:28:53 PM »
I sort of gathered that it was a timestamp, but thanks for parsing it out.
Offline Phil23
    • Phil's Backyard
« Reply #5 on: March 11, 2020, 05:03:41 PM »
https://frankfortweather.us/frankfortblitz/
That's a page I'd like to add to my weather site. With a slight variation.
Map at the top with our region; stats below.
Will that code become available for users to modify & put up on their own sites?
Cheers
Phil.
(Stat 1928)
Edit,
Can see the source, but presume there's a bit more to it than that.
« Last Edit: March 11, 2020, 05:15:15 PM by Phil23 »
« Reply #6 on: March 11, 2020, 09:52:20 PM »
Cheers
Phil.
(Stat 1928)
Edit,
G'day, Phil
 :-"  Well, that page is more-or-less an experiment, but here's a quickie...
 try this:
https://frankfortweather.us/frankfortblitz/blitz1928/
and you can download the small 1928 package here
You can move and update stuff as you will... not too complex.... hope I got timezone correct....
Cheers!
Mike
Offline Phil23
    • Phil's Backyard
« Reply #7 on: March 14, 2020, 05:50:15 PM »
Will play around with it as time permits.
Have it sitting here for now, http://weather.inverellit.com/bt/ & in time will add it somewhere within my menus.
Phil.
Edit:- The Time zone is currently correct. Does it adjust for daylight savings, which end here in a few weeks.
« Last Edit: March 14, 2020, 05:54:30 PM by Phil23 »
Offline vinesweather
    • The Vines Weather
« Reply #8 on: March 15, 2020, 06:30:44 PM »
Hi
Just noticed Egon added this last night\yesterday.
Cheers
Chris
Topic here:
Offline staccermaccer
    • Weather in Ekeren and Port of Antwerp
« Reply #9 on: April 01, 2020, 05:53:04 AM »
Hi, Cutty!
Have been playing around with your template, my station is on the page and it works sort of; the clocks i can manage too; but how do i get the lat and lon right?
This is the code that i changed:
<img height="181" src="https://map.blitzortung.org/statistic_1.php?station=2274&amp;region=1&amp;weeks=1&amp;header_line=0&amp;header_text=0&amp;drawing_area_height=150.png?" alt="689" />
</div>
  <div id="edd" style="">
<iframe name="content_frame" src="https://map.blitzortung.org/index.php?interactive=0&amp;NavigationControl=0&amp;FullScreenControl=0&amp;Cookies=0&amp;InfoDiv=0&amp;MenuButtonDiv=0&amp;ScaleControl=0&amp;LinksCheckboxChecked=1&amp;LinksRangeValue=10&amp;MapStyle=0&amp;MapStyleRangeValue=10&amp;Advertisment=0&#35;2.76/-4.42/51.28"></iframe>
</div>
If you could give me some pointers?
Thanks in advance!
Marc AKA staccermaccer,
« Reply #10 on: April 01, 2020, 09:54:18 AM »
Hi, Cutty!
Hi Marc...
Simplest way to change coordinates only, is click on the active map, zoom and place image as you will, then copy the URL from the browser nav page:
e.g.
https://map.blitzortung.org/#4.05/49.97/4.92
then in your code, at the end, copy the
#4.05/49.97/4.92"> from the new url
and replace
#35;2.76/-4.42/51.28"> in the code
with
#4.05/49.97/4.92">
Hope that helps...
I'm fiddling with a rather confusing 'one stop' page to monitor and control my three stations from a single webpage, but will work great for a single station, also, which currently looks like the video below.
 I'll get around to making active in both public and private formats soon, hopefully, with templates, ideas... bear with me... it's complex for an old guy like me who doesn't speak PhP or other such languages... heh...Quick Look here:
Video Overview
Cheeers!
Mike
« Last Edit: April 01, 2020, 10:04:14 AM by Cutty Sark Sailor »
« Reply #11 on: June 02, 2020, 08:37:54 AM »
Hi, Cutty and others who are interested...
This is the page i made with the script:https://www.akker.be/index.html
Just made a few minor tweaks..
Marc AKA Staccermaccer,
