Author Topic: Power only  (Read 1000 times)
Offline vinesweather
    • The Vines Weather
Power only
« on: February 23, 2020, 05:37:24 AM »
Hi All
 Plugged into 1 amp ub adaptor. Have power light, but no signal or sound. I have assembeld the board, happy with the soldering, no go.
Any suggestions. Is one amp sufficiant to run this?
Many thanks
Chris
Offline dupreezd
Re: Power only
« Reply #1 on: February 23, 2020, 08:30:50 AM »
Chris, a 1A power supply should get you going. What make and model is it?
Here are some suggestions.
Using a DVM, measure the 5V on the controller board.
There are two crystals, make sure you have not swapped them around.
Look on your router, and see if the controller registered an IP address. Then connect to the controller via that IP using a browser.
Dries
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
    • The Vines Weather
Re: Power only
« Reply #2 on: March 03, 2020, 08:21:29 AM »
Thanks mate. I think it's sorted now
