Author Topic: The Coriolis Force on Earth and in the Universe  (Read 2322 times)
Offline Fermer05
« on: February 22, 2020, 11:16:56 AM »
The Coriolis effect occurs when an object approaches or moves away from the axis of the Earth.
At the same time, when an object that moves on the Earth approaches or moves away from the axis of the Sun, the Coriolis Solar Force arises.
The deflecting Coriolis Solar Force, due to the axial and orbital rotation of the Earth, is much more complicated.
The course of the Volga River is constantly pressed against the western bank of the river, by the force of the Coriolis Earth.
And the Coriolis Solar Force, due to the axial and orbital rotation of the Earth, deflects the Volga River first to the west coast, then to the east, twice a day.
For this reason, winding currents form in the seas and oceans.
The aforesaid can be easily verified by rotating the globe around the axis and in orbit. Wrapped along the equator and meridian with a plastic hose in which fluid moves. http://astrogalaxy1.narod.ru/astro016.html
The Coriolis effect of the Earth does not depend on the inclination of the axis of the earth, and the Solar Coriolis force depends.
The solar Coriolis effect is involved in the formation of the moon ellipse.
When the Moon revolving around the Earth in the last quarter approaches the Sun at a speed of 1 km / s, and in the first quarter moves away from the Sun at a speed of 1 km / s, the Coriolis solar force stretches the moon's orbit along the Earth's orbit, due to which an ellipse of the Moon is formed.
When the moon is in the phase of the new moon and the full moon, the solar Coriolis effect does not affect the orbit of the moon, because in these phases the moon does not approach and does not move away from the sun.
https://youtu.be/OZIB_leg75Q
The eccentricity of the orbit of the moon can be approximately calculated by the following formula. E ≈ Vz / Vl = 30/360 = 0,083
Where Vz - Orbital velocity of the Earth - 30 degrees / month.
Vl - Orbital velocity of the moon - 360 degrees / month.
The eccentricity of the Moon’s orbit can be approximately calculated using the following formula.
E ≈ (Vz / Sz) / (Vl / Sl) = 0.00071 / 0.0095 = 0.074
Where Vz - Orbital velocity of the Earth - 107218 km / h.
Sz - Distance from the Sun to the Earth - 150,000,000
Where Vl - Orbital velocity of the moon - 3683 km / h.
Sl - Distance from the Earth to the Moon 384 000км.
The eccentricity of the orbit of the moon varies, from 0.026 to 0.077.
The formula E = Vz / Vl convincingly shows the dependence of the eccentricity of the orbit on the orbital velocity of the planets and satellites.
The solar Coriolis effect also stretches the orbit of artificial Earth satellites, along the Earth’s orbit, by tens of meters. http://www.sat.belastro.net/glava2/glava2.php#p1.2.c
Based on the fact of the approach and removal of the moon from the sun, it is possible to construct. Reactionless drive. https://youtu.be/4_M-fBv5Xmc
The Coriolis solar effect also stretches the Earth along the Earth’s orbit.
Because of the daily rotation of the Earth, the side of the Earth that is at dawn approaches the Sun at a speed of 1600 km / h, and that side of the Earth that is at sunset, moves away from the Sun at a speed of 1600 km / h. Due to what, the Solar Coriolis effect stretches the Earth along the Earth’s orbit by several meters. For this reason, the geological activity of planets and satellites is increasing. https://bigenc.ru/geology/text/v/2335654
The existence of the Coriolis humps can be easily verified if, through a fixed telescope, one observes the geostationary satellite of the Earth during the day. https://bigenc.ru/physics/text/3199621
The video shows how the Coriolis Solar Force stretches the Earth and the Moon’s orbit along the Earth’s orbit. https://youtu.be/JgU93nrv0iA
The reason for the geological activity of the planets is also the Solar Coriolis effect.
The larger the diameter, axial and orbital velocity of the planets and satellites, the more the core of the planets and satellites is heated.
The high geological activity of the satellite Jupiter Io can be explained by the fact that the axial and orbital velocity of Io is 15 times higher than that of the Moon.
The orbital speed of Io is 17 km / s, and the orbital speed of the moon is 1 km / s.
The axial speed of Io is 1 revolution in 42 hours, and the axial speed of the Moon is 1 revolution per month.
The distance from Jupiter to Io, the surface temperature and the diameter of Io, are the same as that of the Moon.
Geologically active are also Earth, Jupiter, Ceres, Enceladus and others.
The geological activity of Venus and Mercury, due to slow rotation, is extremely low. https://images.app.goo.gl/EC2iXou7XDLBWMB66
If Io approaches Jupiter, then Io’s axial and orbital speed will increase, due to which the Coriolis Solar Power can tear Io into numerous pieces, which will then be located along Io’s orbit, forming a ring.
Perhaps the Comet of the Shumeikers - Levi 9, was torn by the Coriolis Solar Effect when it at perihelion approached Jupiter.
At the time of the comet rupture, the distance from Jupiter to the comet reached about 40,000 km., And the orbital speed was 60 km / s. https://en.m.wikipedia.org/wiki/Comet_Shoemaker%E2%80%93Levy_9
It is possible that the asteroid belt was formed from a planet that, due to an increase in axial velocity, was torn by the Coriolis Solar Force.
https://en.m.wikipedia.org/wiki/Asteroid_belt
The coefficient of biological activity of the planets depends on the equatorial and orbital velocity of the planets.
The Earth’s orbit is formed by the Galactic Coriolis force.
When the Earth, revolving around the Sun, approaches and moves away from the center of the galaxy at a speed of 30 km / s, the galactic Coriolis force stretches the Earth’s orbit along the orbit of the Sun, due to which the Earth’s orbit similar to the Lunar one should form. https://en.m.wikipedia.org/wiki/Galactic_year https://en.m.wikipedia.org/wiki/Milky_Way
But the orbits of the planets and comets are not elongated along the orbit of the Sun, which means that the Sun does not rotate around the center of the galaxy, but is in space, in a stationary state. https://m.habr.com/en/post/411567/
The objects of the solar system cannot endlessly revolve around numerous centers.
The laws of celestial mechanics are not omnipotent and are limited by the task of three bodies. The Earth revolves around the Sun, the Moon revolves around the Earth, and nothing revolves around the Moon. No natural planetary satellite has a permanent or temporary satellite, because this will be the task of four bodies, which contradicts the laws of being.
In nature, there is no relationship without symbiosis, and in the center of the galaxy, the solar system does not need.
https://spaceworlds.ru/solnechnaya-sistema/orbity-planet.html
And the main question is why planetary satellites do not have satellites, and asteroids possess satellites. Despite the fact that asteroids are much smaller than planet satellites. https://en.m.wikipedia.org/wiki/Minor-planet_moon
The two satellites of Saturn, Janus and Epimetheus, move in the same orbit, and overtake each other every four years.
If these two satellites revolved around the Sun, then Janus would capture Epimetheus. https://elementy.ru/kartinka_dnya/430/Tanets_Yanusa_i_Epimeteya
Based on the foregoing, we can put forward the hypothesis of the formation of the solar system.
1. The solar system is an autonomous object of the Universe and does not revolve around the center of the "galaxy" but is in space, in a stationary state.
2. Sunlight, due to the deflecting force of the Coriolis, revolves around the solar system.
3. At the edge of the solar system, sunlight rotates against the rotation of the sun, at a speed of about 0 km / s, relative to the universe. https://images.app.goo.gl/GZMt3h1e1dH86wWN6
4. The radius of the solar system depends on the speed of light and the angular velocity of rotation of the sun. R ≈ c / ω
The speed of light ≈ 1,000,000,000 km / h.
The angular velocity of the Sun ≈ 0.0105 rad / h.
The radius of the solar system is ≈ 95,000,000,000 km.
http://universetoday-rus.com/blog/2008-07-16-10
5. I believe the stars are huge luminous balls that formed from sunlight.
6. Sunlight transforms into nebulae, stars, globular clusters, galaxies, Kuiper belt, asteroids, protoplanets, planets, which after billions of years, spinning, fall back onto the Sun. There is a cycle of solar matter in nature. Otherwise, for billions of years of its existence, the Sun has long been burned.
7. A planet is an object in the solar system that has an atmosphere, daily rotation, etc. https://en.m.wikipedia.org/wiki/IAU_definition_of_planet
8. The hypothesis that the Moon was formed from the rings of the Earth, and Mercury is a former satellite of Venus, is within the laws of celestial mechanics.
9. Outside the solar system, sunlight does not penetrate and it will be impossible to see the solar system from the side of the universe.
10. All mechanical processes that occur in the atmosphere also occur in the starry sky.
11. The theory of the evolution of the Universe should not contradict and go beyond the laws of celestial mechanics. http://www.ponjatija.ru/node/938
Everything is relative!!!
The mechanism of rotation of cyclones, anticyclones, cycles and galaxies is one and the same. This can be verified by comparing these two pictures.
https://images.app.goo.gl/1QaUggrb6N1qQ3xF8 https://images.app.goo.gl/xozpZJsAfkq1owoX9
The galaxy is a single slowly rotating "monolith", which does not obey the law of gravity, because all stars in galaxies rotate with the same angular velocities (like a gas tank cover).
And in the solar system - the farther from the sun the planet is, the lower the orbital speed of the planet. While Neptune makes one revolution around the Sun, Mercury makes more than 500 revolutions.
The orbital speed of Mercury is 50 km / s, and Neptune is 5 km / s. https://life.ru/p/907112
Based on the foregoing, we can conclude that in the center of the galaxy is the eye of the storm, and not a black hole and dark matter. https://en.m.wikipedia.org/wiki/Eye_(cyclone) https://en.m.wikipedia.org/wiki/Galaxy_rotation_curve
Black holes leave their galaxies. https://news.rambler.ru/scitech/43938566-astronomy-pokazali-kak-chernye-dyry-pokidayut-svoi-galaktiki/ https://youtu.be/pnbJEg9r1o8
Astronomers accidentally discovered a strange star escaping from the Milky Way.
https://in-space.ru/astronomy-sluchajno-obnaruzhili-strannuyu-zvezdu-ubegayushhuyu-iz-mlechnogo-puti/ https://youtu.be/f_w6JprsXK8
The black hole spawned a unique kind of planet. https://m.lenta.ru/news/2020/04/27/hole/amp/
Own movement of stars. https://spacegid.com/zvezda-barnarda.html
Regeneration of cyclones. https://slide-share.ru/regeneraciya-anticiklonov-28872
There are no answers to the following questions:
1. In the solar system, all eight planets revolve around the sun in the same plane.
a) And the stars, rotating around the nucleus of the galaxy, form dozens of planes.
b) What force is involved in the formation of the lenticular form of the galaxy?
c) Within the laws of celestial mechanics, stars should rotate around the core of the galaxy in only one plane, similar to the planets of the solar system.
2. The statement that globular star clusters are satellites of galaxies and rotate in very elongated orbits at a speed of ≈ 200 km / s also goes beyond celestial mechanics. https://images.app.goo.gl/7HbHogMoCKWPswX18
a) If only globular star clusters revolved around the galaxy, then globular star clusters would have a disk shape. https://en.m.wikipedia.org/wiki/Galaxy
b) Will Saturn and its satellites be able to rotate around the Sun, in the form of a globular cluster?
3. In globular star clusters, there is no orbital rotation of stars.
a) Then what forces form a globular cluster of stars, if it is not levitation?
4. If globular star clusters are satellites of galaxies, then star clusters should have, rotation axis, libration, etc. https://en.m.wikipedia.org/wiki/Globular_cluster
The hypothesis of the formation of a record super-new moon.
As we know the length of the lunar ellipse depends on the orbital velocity of the Earth.
The monthly orbital velocity of the Earth increases monthly in the new moon phase, which increases the length of the lunar ellipse. At the same time, the height of the lunar ellipse decreases accordingly, due to which, in the new moon phase, the Moon becomes closer to the Earth, and as a result a super-new moon is formed.
In winter at perihelion, the orbital velocity of the Earth rises.
During the coincidence of the perihelion of the Earth and the new moon, the orbital velocity of the Earth reaches its maximum value, due to which a record super-new moon and super-full moon are formed.
In the summer in aphelion, in the new moon phase, only the super-new moon is formed.
Calendar of record super moons. https://predicalendar.ru/wiki/moon/super-moon/
December 3, 2017, Sunday
January 2, 2018, Tuesday
January 21, 2019, Monday
February 19, 2019, Tuesday.
https://en.m.wikipedia.org/wiki/Supermoon
Criticism of the existing theory of record super moon.
Super moon - occurs when the full moon or new moon coincides with perigee, as a result of the rotation of the orbit of the moon. At a speed of one revolution in 8.8 years.
It means:
That every 8.8 years super moon happens.
And given the fact that the moon’s orbit rotates extremely slowly, 1 revolution in 8.8 years, then the super moon lasts about a year.
At the same time, if the moon is super full in perihelion, then in the aphelion, after half a month, micro new moon should occur.
But such a natural phenomenon is not observed in nature.
https://images.app.goo.gl/aRfBpPhE2eTMB3YaA
https://en.m.wikipedia.org/wiki/Apsidal_precession
2) What force rotates the orbit of the moon?
3) Why the record-breaking super moon is not formed in the summer.
4) Why is the record super new moon more than the super full moon.
5) The Moon’s orbit does not rotate and does not make one revolution in 8.8 years, since the Solar Coriolis force stretches the Moon’s orbit along the Earth’s orbit.
And the orbits of the planets rotate, because, the Coriolis force does not affect the orbits of the planets.
https://en.wikipedia.org/wiki/Newton%27s_theorem_of_revolving_orbits
6) The major axis of the moon's ellipse is always elongated along the Earth’s orbit, and does not become perpendicular to the Earth’s orbit.
Earthquake hypothesis.
The cause of tremors may be the explosion of volcanic gases as a result of self-ignition of compressed gas. An explosion can also occur as a result of contact between magma and volcanic gases, or from an electric discharge.
If the explosion can break through the crust of the planet, a volcano will form; if it cannot, an earthquake occurs.
https://spravochnick.ru/geografiya/vulkany/vulkanicheskie_zemletryaseniya/
Manifestations of volcanic earthquakes are no different from tectonic earthquakes. And it is possible that tectonic theory is a duplicate theory.
In Japan, a volcanic gas explosion crushed a mountain 670 m high. In Indonesia, a volcanic gas explosion destroyed half of the volcano and caused an earthquake in several cities, and there are quite a few such facts.
90 percent of volcanoes are in seismically active zones. Every day, up to 5,000 earthquakes occur on Earth, which last 5-20 s on average. https://ria.ru/20080827/150711010.html
Criticism of the earthquake tectonic theory.
1. There are no convincing facts that tectonic plates exist.
2. Why earthquakes occur, both at the junction of tectonic plates, and in the center of the plate?
3. The assertion that the plates move due to the temperature difference in the bowels of the Earth is doubtful.
4. It is also doubtful that lithospheric plates can sink in the mantle of the planet, reaching the depth of the outer core.
a) If the lower lithospheric plates easily sink in the mantle of the earth, then during the crawl of the plates, the lower plate should easily fall down.
 b) It is possible to carry out a simple experiment if, in the pool, two rubber or wooden plates are moved towards each other. https://youtu.be/3I_Eoo6XQ-U
5. Tectonic plates cannot have spring properties.
6. Centrifugal force acts on the earth's crust due to the rotation of the earth, but due to the orbital rotation of the earth, the centrifugal force of the earth fluctuates. Due to this, there is a mixing of the earth's crust, but not an earthquake. It is also possible that over the years the volume and mass of land is growing. http://www.evgengusev.narod.ru/spb/zhirnov-2011.html
Continuation: "The mechanism of thermoregulation of the Earth."
Forum on the flagship. https://vmf.net.ru/forums/viewtopic.php?f=6&t=2328&sid=a49d602d08c50eda4f043b73838e5f8a
Forum of Nizhny Novgorod State University named after N.I. Lobachevsky.
http://forum.unn.ru/viewtopic.php?f=39&t=10331&sid=cfbc49e0cf32263eff20888ca205ab15
The opening was published in the Russian-German peer-reviewed journal “Eastern European Scientific Journal” No. 3/2015. Page 64. June
Scientific journal NBIKS-Nauka.Tehnologii No. 4/2018. Page 104. (Nanotechnological Society of Russia).
French Maritime Forum. http://forummarine.forumactif.com/t9357-le-flux-et-reflux-est-le-resultat-de-la-rotation-de-la-terre
English forum. "Weather / Earth Sciences" https://www.wxforum.net/index.php?topic=35094.0
« Last Edit: Yesterday at 09:05:07 PM by Fermer05 »
Offline waiukuweather
Re: Earthquake hypothesis
« Reply #1 on: February 22, 2020, 03:17:39 PM »
it is true there is a slight bulge due to the moon on the earth surface (i.e a tidal bulge), as satellites have measured that
but there is no evidence that causes or triggers earthquakes
you can imagine and argue your thoughts all you like though I guess
Offline weather34
« Reply #2 on: February 22, 2020, 03:55:12 PM »
science and local myths still no closer to predicting earthquakes ..
Oarfish have been said to forecast earthquakes.
In Japan, oarfish have long figured into folklore. Smaller than the giant oarfish, the related slender oarfish (Regalecus russelii) is known there as the "Messenger from the Sea God's Palace." And according to traditional belief, if many of the fish wash up, it may signal a coming earthquake.
According to Japan Times, there could be some scientific basis to that story, even if scientists don’t currently use fish behavior to predict tremors. Kiyoshi Wadatsumi, a scientist who studies earthquakes at the nonprofit organization e-PISCO, told the paper, “Deep-sea fish living near the sea bottom are more sensitive to the movements of active faults than those near the surface of the sea.”
Offline davidmc36
  • Morewood Ontario Canada
    • IONOTTAW14
It was interesting the first few lines but too much verbal diarrhea to maintain concentration.
Condense your concepts.
Offline davidmc36
    • IONOTTAW14
Dark Matter
all those things are actually true
Offline Fermer05
Re: The Coriolis Force on Earth and in the Universe
« Reply #6 on: June 29, 2020, 01:45:25 AM »
Secrets of the orbit of the moon.
From the foregoing, we can conclude that:
1) The Moon’s orbit is always extended along the Earth’s orbit and does not rotate counterclockwise, making one revolution in 8.8 years. https://en.m.wikipedia.org/wiki/Apsidal_precession
2) It is believed that at perihelion, the moon is at 50 thousand km. closer to Earth than aphelion, why is this huge difference not visually observed? https://images.app.goo.gl/wmqRKPc9jzScCrB16
3) The earth is in the center of the ellipse of the moon and not to the side, this can be easily checked. By measuring the time of the movement of the moon, from the new moon to the full moon and from the full moon to the new moon.
4) What force does not give the barycenter of the Earth and the Moon is in the center of the orbit of the Moon? http://regul238_f27w5b.radius-host.net/forum/zemlja-luna.gif
5) The moon does not move, 15 days from the new moon to the full moon and 14 days from the full moon to the new moon. https://images.app.goo.gl/wmqRKPc9jzScCrB16
« Reply #7 on: June 29, 2020, 03:48:56 AM »
re 1
the moon rotates once in the 28 days it takes to orbit earth
(gravity locked)
re 2
it is visibly noticable (brighter and bigger)
Offline Fermer05
« Reply #8 on: July 06, 2020, 04:29:41 PM »
The eccentricity of the orbit of the moon can be calculated by the following formula.
Where Vz - Orbital velocity of the Earth - 107 000 km / h.
Where Vl - Orbital velocity of the moon - 3680 km / h.
Eccentricity is also affected by satellite libration.
