Stationary model of the solar system.
Community of Russian scientists.
https://vk.com/rosuch1. The solar system is an autonomous object of the Universe, is in a stationary state in space and does not rotate around the center of the galaxy.
2. Sunlight approaching the edge of the Solar System, under the influence of the Coriolis force of the Sun, is deflected and begins to move along the perimeter of the Solar System, against the rotation of the Sun.
3. The sunlight then slows down, breaks up into particles and collapses into a star, causing the kinetic energy of the light to be transformed into the rotational energy of the stars.
https://en.m.wikipedia.org/wiki/Oort_cloud4. At the edge of the Solar System, the mass of stars, the force of gravity, the speed of light, as well as the orbital speed of stars, globular clusters and galaxies are close to zero.
The farther a star is from the Sun, the lower the orbital speed of the stars.
https://en.m.wikipedia.org/wiki/Plasma_(physics)
5. The star, being in a state of weightlessness, floats along the edge of the Solar system in the form of balls, globular clusters and galaxies in the direction of the rotation of the Sun, relying on the laws of celestial mechanics and temperature differences - the Yarkovsky effect.
https://images.app.goo.gl/y8B4LuoyEvVU2Yfr6 https://images.app.goo.gl/T6SH4NYKDf2wxdSQ86. Approaching the Sun, the stars compress and become denser, due to which the temperature and brightness of the stars increases and globular clusters, galaxies and asteroids are formed.
Most of the mass of the Solar System comes from the Sun and the ecliptic plane, due to which asteroids orbiting the Sun slowly approach both the Sun and the ecliptic plane, resulting in the formation of the Kuiper Belt.
Then planets emerge from the Kuiper belt, surrounded by a system of rings from which satellites are formed.
As they approach the Sun, the orbital speed of the planets increases, as a result of the transformation of the axial speed of the planets into orbital speed. (Mechanics of interaction of two bodies).
https://studfile.net/preview/5851639/page:4/7. Further, as they approach the Sun, the temperature, axial and orbital speed of the planets and satellites increase, due to which the satellites are thrown out of orbit and the planets are overturned.
https://youtu.be/QaO9gC9EXNI?si=rOzRc9TaFdQGpHDbWhen the planet comes close to the Sun, the geological activity of the planets increases, resulting in an explosion of the combustible mixture in the fractures of the planets, and as a result the planet is destroyed into fragments, similar to Comet Shoemaker - Levy 9.
Then fragments of the planets, rotating around the Sun at a speed of tens of km/sec, crash into the surface of the Sun, due to which the axial speed of the Sun increases.
http://www.sai.msu.su/ng/solar/comets/main_sl9.html The self-ignition temperature of gases is about 500 degrees.
8. The radius of the Solar System depends on the speed of light and the angular speed of rotation of the Sun. R ≈ c/ω
The speed of light is ≈ 1,000,000,000 km/h.
The angular speed of rotation of the Sun is ≈ 0.0105 rad/h.
The radius of the Solar System is ≈ 95,000,000,000 km.
9. The Earth and Moon pair, in an elliptical orbit, rotate around a common center of mass and move in the direction of rotation of the Sun.
A photon consists of two particles rotating around the center of mass, which move in space against the rotation of the Sun, thanks to the deflecting Coriolis force of the Sun.
https://en.m.wikipedia.org/wiki/LightThe photon and the Sun are interconnected by gravity, just like the Sun, Earth and Moon. (Three body problem).
The more the gravity of the Sun affects the particles of the photon, the more the orbit of the particles is extended and the greater the speed of the Photon.
https://en.m.wikipedia.org/wiki/PhotonAt the edge of the Solar System, as the Sun's gravity decreases, the ellipse of particles also decreases, due to which the Photon slows down and breaks up into two particles.
Next, a particle of light moves from the edge of the solar system to the Sun for billions of years, possessing enormous potential energy, which can be calculated using the following formula.
U = (Ms+mch)•r
Ms - Mass of the Sun. mch - Particle mass.
r - Distance from the Sun to the particle.
Without the gravitational influence of the Sun, the Earth-Moon Pair and Photon disintegrate.
Based on the mechanics of interaction of three bodies, it is possible to construct a supportless propulsion device.
https://youtu.be/um5nS-vA9is?si=ORVhOM36rKW2PcKZ And its transformations.
https://youtu.be/4_M-fBv5Xmc?si=3nRFzsUytTQDqqvb10. Proper motion of stars.
https://en.m.wikipedia.org/wiki/Proper_motionGalaxies, atmospheric cyclones and anticyclones rotate around their own axis and in orbit, and everything that rotates, including gyres, has the property of a gyroscope to maintain the vertical position of the axis in space, regardless of the rotation of the Earth, due to which blocking and then drift of galaxies occurs.
The direction of galaxy drift depends on the inclination of the axis and orbit of the galaxies relative to the ecliptic plane.
Due to the gyroscope properties that galaxies have, galaxies drift around the entire perimeter of the Solar System rather than aligning themselves in the ecliptic plane.
https://youtu.be/aj-RClXNloc?si=AK_KmsP1X9tcl0HzThe closer the orbit of stars is to the Sun, the faster the star moves, and the further the orbit of stars is from the Sun, the slower the star moves. Perhaps the orbit of Barnard's flying star is located either far from the Sun or close to the Sun.
https://www.winstein.org/publ/1-1-0-8325https://en.m.wikipedia.org/wiki/File:61_Cygni_Proper_Motion.gifThe satellites of Saturn and the star of the galaxy move much faster in the full moon phase than in the new moon phase.
11. I believe that a star, like planets, reflects sunlight.
a) If the stars emitted light in all directions, then we would see only those stars that are located close to the Sun, and the star could be observed both during dawn and during sunset and during the day.
https://en.m.wikipedia.org/wiki/Color_temperatureb) What has been said can be verified by experiment.
12. It is believed that the farthest stars are located at a distance of about 10 billion light years from us.
a) How does sunlight travel such distances and how far can sunlight travel?
13. So little solar energy and light comes to Pluto that our star can be confused with a large star. Sunlight on Pluto is thought to be 1,600 times dimmer than on Earth.
https://spainproject.ru/gable/kak-vyglyadit-solnce-s-raznyh-planet-kak-vyglyadit-solnce-na-drugih/14. Outside the solar system, sunlight does not penetrate and it will be impossible to see the solar system from the side of the universe.
15. All mechanical processes that occur in the atmosphere also occur in the starry sky.
The assertion that the solar system revolves around the center of the Galaxy does not stand up to criticism.
If the Solar System revolved around the center of the Galaxy, then the Earth, rotating around the Sun, would approach and move away from the center of the Galaxy, as a result of which the Earth’s orbit, thanks to the Coriolis force of the Sun, would be elongated along the orbit of the Sun. Similar to the lunar orbit.
https://en.m.wikipedia.org/wiki/Galactic_year https://en.m.wikipedia.org/wiki/Milky_Way But the orbits of the planets are not elongated along the “orbit of the Sun”, this means that the Sun does not rotate around the center of the galaxy but is stationary in space.
https://m.habr.com/ru/post/411567 Objects in the Solar System cannot endlessly rotate around numerous centers.
The laws of celestial mechanics are not omnipotent and are limited to the three-body problem; the Earth revolves around the Sun, the Moon revolves around the Earth, and nothing revolves around the Moon.
No natural satellite of the planets has a permanent or temporary companion, as this would already be a four-body problem, which is contrary to the laws of being.
For this reason, the artificial satellites of the Earth rotate by inertia much longer than the artificial satellites of the Moon.
https://naked-science.ru/qa/518331 And the most important question is why asteroids have satellites, but planetary satellites do not have satellites, despite the fact that planetary satellites are much more massive than asteroids.
https://en.m.wikipedia.org/wiki/Subsatellite Saturn's two moons, Janus and Epimetheus, move in the same orbit and pass each other every four years. If these two satellites orbited the Sun, then Janus would have captured Epimetheus.
https://elementy.ru/kartinka_dnya/430/Tanet...usa_i_Epimetey In nature there is no relationship without symbiosis, and the solar system does not need the center of the galaxy.
Comet Galya orbits the Sun every 75 years, in a highly elongated orbit, due to the fact that the Sun does not revolve around the center of the Galaxy.
The Big Bang theory was born from the observation that other galaxies are moving away from ours at great speed in all directions, and based on this hypothesis the Big Bang hypothesis was written.
https://bigenc.ru/c/teoriia-bol-shogo-vzryva-2178441. Thanks to what forces the Universe assembles and explodes. Without an answer to this question, the Big Bang hypothesis has no right to exist.
2. After the Big Bang, the Galaxies, having received fantastic kinetic energy, must move in a straight line and forever.
3. The center of the Solar system is the Sun, and the role of the Sun for the Solar system is vital, but what role does the center of the Universe play for the Universe, what is there and what happens?
4. What was the state of the laws of celestial mechanics before the explosion, at the moment of the explosion, and after the explosion, how and when did they arise?
5. Moving away from the center of the Universe, the galaxies began to rotate around their own center, what force rotates the galaxies and where did this force come from?
6. The statement that globular star clusters are satellites of Galaxies and rotate in highly elongated orbits at a speed of ≈ 200 km/sec also goes beyond the scope of celestial mechanics.
a) If globular clusters rotated around the center of the Galaxy, then they would rotate in the same plane.
https://en.m.wikipedia.org/wiki/Galaxyb) Will Saturn and its moons be able to orbit the Sun as a globular cluster?
7. In globular clusters there is no orbital rotation of stars.
a) Then what forces form a globular cluster of stars?
8. If globular clusters are satellites of Galaxies, then globular clusters, like all satellites of planets, must have all the attributes of satellites: rotation axis, libration, etc.
https://en.m.wikipedia.org/wiki/Globular?9. After expansion, the Universe contracts back and Galaxies rush towards the center of the Universe with enormous speed.
10. For what reason the galaxies stopped scattering and began to gather.
11. What force attracts galaxies to the center of the Universe, if it is a gravitational force, then how does it arise?
12. How much energy is released when a galaxy collides with the center of the Universe.
https://bigenc.ru/c/singuliarnost-prostranstva-vremeni-867893 Coriolis force on Earth and in the Solar System.
https://en.m.wikipedia.org/wiki/Coriolis_forceThe Coriolis force occurs when an object approaches or moves away from the Earth's axis.
At the same time, when an object that moves on or around the Earth approaches or moves away from the axis of the Sun, the Solar Coriolis force is generated.
The deflecting Solar Coriolis force, due to the axial and orbital rotation of the Earth, is somewhat more complex.
The flow of the Volga River is constantly pressed against the western bank of the river by the Coriolis force of the Earth, and the Solar Coriolis force, due to the axial and orbital rotation of the Earth, deflects the flow of the Volga River either to the western bank or to the eastern bank twice a day. For this reason, winding currents form in the seas and oceans.
https://en.m.wikipedia.org/wiki/MeanderThe above can be easily verified by rotating a globe around its axis and orbit, entwined along the equator and meridian with a polyethylene hose in which the liquid moves.
http://astrogalaxy1.narod.ru/astro016.htmlThe Coriolis effect of the Earth does not depend on the inclination of the axis of the earth, and the Solar Coriolis force depends.
The solar Coriolis force is involved in the formation of the Moon's ellipse.
When the Moon, rotating around the Earth in the last quarter approaches the Sun at a speed of 1 km/sec, and in the first quarter moves away from the Sun at a speed of 1 km/sec, the Solar Coriolis force slightly stretches the Moon's orbit along the Earth's orbit, due to which the Moon's elliptical orbit is formed .
https://images.app.goo.gl/wmqRKPc9jzScCrB16When the Moon is in its new and full moon phases, the Solar Coriolis Force does not affect the Moon's orbit because During these phases, the Moon does not approach or move away from the Sun.
The eccentricity of the Moon's orbit can be calculated using the following formula. E = Vz / Vl = 0.0411 / 0.55 = 0.0747
Where Vz - Earth's orbital speed - 0.0411 degrees / hour.
Vl - Moon's orbital speed - 0.55 degrees / hour.
E = (Vz / Sz) / (Vl / Sl) = 0.00071 / 0.0095 = 0.0747
Where Vz is the Earth's orbital speed - 107,218 km / h.
Sz - Distance from the Sun to the Earth - 150,000,000 km.
Where Vl is the Moon's orbital speed - 3683 km / h.
Sl - Distance from the Earth to the Moon 384,000 km.
The eccentricity of the Moon's orbit varies, from 0.026 to 0.077.
Both formulas show that the average eccentricity of the Moon's orbit is 0.0747.
And the average eccentricity of the moon's orbit, obtained using radar, is 0.054.
http://www.aggregateria.com/R/radiolokatsionnaja_astronomija.htmlAlso, the eccentricity of the Moon's orbit can be determined by the following formula. E = Vl / Vz = 27.3 / 365.2 = 0.0747
Where Vl is the Moon's orbital angular velocity.
Vz - Orbital angular velocity of the Earth.
By dividing the orbital speed of the Moon by the eccentricity of the Moon's orbit, the Earth's orbital speed can be calculated.
https://en.m.wikipedia.org/wiki/MoonBased on the fact of the approach and removal of the moon from the sun, it is possible to construct. Reactionless drive.
https://youtu.be/4_M-fBv5XmcThe Moon, rotating around the Earth, approaches and moves away from the Earth, due to which the Moon periodically falls into resonance, and as a result, a supermoon and a micromoon occur.
https://en.m.wikipedia.org/wiki/Supermoon The reason for the resonance of the Moon's orbit is the uneven orbital speed of the Moon.
https://www.booksite.ru/fulltext/1/001/008/056/700.htm Artificial satellites of the Moon also enter into resonance - chaotic rotation.
Why do artificial satellites of the Earth rotate by inertia much longer than artificial satellites of the Moon?
https://de.m.wikipedia.org/wiki/MasconIt is believed that the orbit of the Earth and the Moon rotates and completes one revolution every 112,000 and 8.8 years.
The rotation of the Moon's orbit is in doubt, since the Coriolis force of the Sun constantly stretches the Moon's orbit along the Earth's orbit.
https://en.m.wikipedia.org/wiki/Apsidal_precession1. Planets and satellites, rotating around the Sun and around their axis, have axial and orbital kinetic energy, which is transformed from axial energy to orbital, and from orbital to axial.
a) The Earth, rotating around its axis, transfers its axial energy into orbital energy, and Mercury transfers its orbital energy into axial energy, due to which the Earth moves away from the Sun, and Mercury approaches the Sun.
b) Venus transfers its orbital speed to the axial one, and rotates the planet to the left, and the atmosphere of Venus rotates Venus to the right, which is why Venus quickly loses orbital energy.
The transformation of the speeds of Mercury and Venus occurs at perihelion.
https://www.fieldphysics.ru/mercury_perihelion/c) I believe that the physical libration of the Moon in longitude is the result of the transformation of the orbital energy of the Moon into the axial energy of the Moon.
https://en.m.wikipedia.org/wiki/LibrationThe Earth's orbital speed is transformed into the Moon's orbital speed.
https://youtu.be/um5nS-vA9isd) The atmosphere also participates in the axial rotation of the planets - atmospheric transfer, the speed of which depends on the temperature difference between the night and day sides of the planet.
https://dic.academic.ru/dic.nsf/ruwiki/1302676e) The transformation coefficient, orbital inclination, shape and speed of rotation of orbits depend on the axial and orbital speed of the planets and the angle of inclination of the rotation axis to the orbital plane.
https://youtu.be/aj-RClXNlocf) In celestial mechanics, the transformation of velocities occurs due to the mechanics of interaction of two and three bodies, which can be expressed in the form of a structure.
https://youtu.be/4_M-fBv5Xmc https://youtu.be/um5nS-vA9isThe reason for the geological activity of the planets is also the Coriolis solar force.
The side of the Earth located at dawn, as a result of the axial rotation of the Earth, approaches the Sun at a speed of 1600 km/h, and the side of the Earth located at sunset moves away from the Sun at a speed of 1600 km/h. due to which the Solar Coriolis force stretches the Earth along the Earth’s orbit, and as a result, the geological activity of planets and satellites increases. (Rotating planets heat up, like a flat tire on a car.)
The high geological activity of Jupiter's moon Io can be explained by the fact that the axial and orbital velocity of Io is 15 times greater than that of the Moon.
Io's orbital speed is 17 km / s, and the Moon's orbital speed is 1 km / s. Io's axial velocity is 1 revolution per 42 hours, and the moon's axial velocity is 1 revolution per month.
The distance from Jupiter to Io, the surface temperature and diameter of Io are the same as those of the Moon.
Geologically active are also Earth, Jupiter, Ceres, Enceladus, etc.
The geological activity of Venus and Mercury, due to the slow rotation, is extremely low.
https://images.app.goo.gl/EC2iXou7XDLBWMB66If Io gets closer to Jupiter, then the axial and orbital velocity of Io will increase, due to which the Solar Coriolis force can tear Io into numerous pieces, which will then be located along Io's orbit, forming a ring.
Perhaps the Shoemaker Comet, Levi 9, was torn apart by the Solar Coriolis effect as it approached Jupiter at perihelion.
At the time of the comet's rupture, the distance from Jupiter to the comet reached about 40,000 km, and the orbital speed was 60 km / s.
https://en.m.wikipedia.org/wiki/Comet_Shoemaker%E2%80%93Levy_9The coefficient of geological activity of planets depends on the diameter, axial and orbital speed of the planets.
The video shows how the Coriolis solar force is pulling the Earth and the Moon's orbit along the Earth's orbit.
https://youtu.be/AjnA-5WFlgw?si=Ns0Opg18dlIUmRHUContinuation: Forum of Akademgorodok Novosibirsk. The science.
https://forum.academ.club/index.php?showtopic=1235578 Forums of Nizhny Novgorod State University named after. N.I. Lobachevsky.
http://forum.unn.ru/viewtopic.php?f=39&t=10331
