Besuchen Sie unser deutsches Schwesterforum www.wxforum.de
The Davis display head measures "inside" temperature with a poorly placed sensor somewhere in the body of the display unit. It's strange that they did that. In the past, it's always been 5-8 F high from the actual inside ambient, so I will also need to re-attach the little 40 mm fan that I'd placed over the rear vent holes on the display case to attempt to pull the inside-case temp down a bit to make it closer to inside room ambient.
Thanks - I didn't know I could program an offset. Is it linear?
