Author Topic: MesoWest Question  (Read 460 times)
Offline DRoberts
MesoWest Question
« on: February 13, 2020, 08:52:38 AM »
Why am I seeing these "caution" notations? Anything to be concerned with?
I hope I have this question in the right place. Thanks.
Offline racer3
Re: MesoWest Question
« Reply #1 on: February 13, 2020, 12:09:44 PM »
On the left side click on DATA QUALITY. that should give you the answer.
« Reply #2 on: February 13, 2020, 02:57:57 PM »
Offline kq6up
« Reply #3 on: April 27, 2020, 05:51:13 PM »
If you report packets to CWOP, but your data does not pass muster on all the wind/temp do they not post on MesoWest?
Chris KQ6UP
« Reply #4 on: April 27, 2020, 06:22:10 PM »
Chris KQ6UP
You'll see a yellow "Caution" as depicted above, but that's through Meso. CWOP themselves doesn't do any QC. They just muster the PWS's.
Offline kq6up
« Reply #5 on: April 27, 2020, 06:23:08 PM »
How do I get my data listed on MesoWest?  I imagine that is something separate from CWOP.
Chris Maness KQ6UP
« Reply #6 on: April 27, 2020, 06:26:35 PM »
Do you have a MADIS ID?
Offline kq6up
« Reply #7 on: April 27, 2020, 06:29:27 PM »
AV480 is the number the CWOP folks gave me.  Not sure if that is the same or something different.
Regards,
Chris Maness KQ6UP
« Reply #8 on: April 27, 2020, 06:37:04 PM »
I'm assuming that's your ham ID. MADIS ID is like my "handle" or whatever it's called. C2274 is the actual station ID, but the station "name" is CW2274.
All this was done for me by my WFO years ago, so I'm not sure how to "get there".
Here's the CWOP site. Maybe you can glean info, if not, someone else will show you the way.
http://www.wxqa.com/
Offline kq6up
« Reply #9 on: April 27, 2020, 06:39:19 PM »
That is the CWOP site.  I am signed up with them.  Maybe I am confused.  Is all the registered CWOP user's data passed to MesoWest, or is that a separate sign up?
Chris KQ6UP
« Reply #10 on: April 27, 2020, 06:41:47 PM »
Yeah, like I said, it was all done for me so I'm pretty clueless. Guarantee someone else will know.
Offline ValentineWeather
    • LiVE WEATHER
« Reply #11 on: April 27, 2020, 07:08:24 PM »
kq6up
You are on mesowest automatically
You have a different call name than I've seen before.
Found you here:
https://mesowest.utah.edu/cgi-bin/droman/meso_base_dyn.cgi?stn=AV472&unit=0&timetype=GMT
Randy
« Reply #12 on: April 27, 2020, 07:11:09 PM »
Nice find Randy! Concur on the ID, it looks more like a "government" ID like a RAWS or flood monitor station.
Offline kq6up
« Reply #13 on: April 27, 2020, 07:11:32 PM »
Thank you.  I just did not see my station on the meso west map when I searched my area.
Chris KQ6UP
    • LiVE WEATHER
« Reply #14 on: April 27, 2020, 07:12:47 PM »
Randy
    • LiVE WEATHER
« Reply #15 on: April 27, 2020, 07:13:27 PM »
Chris KQ6UP
Look up in upper left corner of first link.
Randy
Offline kq6up
« Reply #16 on: April 27, 2020, 07:14:05 PM »
kq6up
Found you here:
There is a mistake.  AV472 is in Montana.  This error was made a couple of years ago with the CWOP folks.  It was fixed on CWOP's end, but it is wrong on this site.  My correct number for my station is AV480.  Who can fix this?
Chris KQ6UP
Offline kq6up
« Reply #17 on: April 27, 2020, 07:17:55 PM »
Offline kq6up
« Reply #18 on: April 27, 2020, 07:19:13 PM »
Check KQ6UP http://www.wxqa.com/states/CA.html then click on the second 480.  It goes to mesoWest but site not found.
Chris KQ6UP
Offline Storm017
« Reply #19 on: April 27, 2020, 07:20:00 PM »
As for your data it should provided through APRSWXNET/Citizen Weather Observer Program automatically (at least for me it came in automatically). I sign up (about 2 months ago) for an account with Mesowest so I can download historical data.  It was the same for MADIS.
    • LiVE WEATHER
« Reply #20 on: April 27, 2020, 07:21:18 PM »
If this isn't your location fill out the correction on Gladstonefamily pointing to the correct location.
https://weather.gladstonefamily.net/site/search?site=AV480&search=Search
Randy
« Reply #21 on: April 27, 2020, 07:24:27 PM »
kq6up
Found you here:
Chris KQ6UP
Yes, something is screwy. Contact info here.
https://mesowest.utah.edu/html/help/main_index.html
Offline kq6up
« Reply #22 on: April 27, 2020, 07:26:44 PM »
This was already fixed on the CWOP side.  They had our data reversed.  Montana WX was showing up under my CWOP site, and California WX was showing up on his site.  They fixed it, but it is still screwed up in MesoWest.
This is the Montana station:
https://weather.gladstonefamily.net/site/search?site=AV472&search=Search
Look at the "AV" number on the image attached.
« Reply #23 on: April 27, 2020, 07:27:06 PM »
Noticed it's getting flagged on temperature. Others near 90f and this station is reporting 60 or so.
https://mesowest.utah.edu/cgi-bin/droman/mesomap.cgi?lat=34.02100&lon=-117.31400&radius=25&rawsflag=290&site=AV472&unit=0&time=LOCAL&product=&year1=&month1=&day1=00&hour1=00&currTimeChecked=
Yeah... he's got HUGE problems...and not just temp.
https://mesowest.utah.edu/cgi-bin/droman/regress_database_top.cgi?stn=AV472
That is WX in Montana.  Not from my station, and not my error.
Yes, I removed it after I observed the error. I'd go to Meso contact first. Who knows if Gladstone is even home.
Offline kq6up
« Reply #24 on: April 27, 2020, 07:27:58 PM »
Gladstone was fixed a LONG time ago.
