Author Topic: Discrepancy VP2 and Weatherlink Live  (Read 147 times)
Offline Oilswell
« on: February 10, 2020, 10:32:52 PM »
So I just got both VP2 and WLL setup today and so far so good with the exception of a discrepancy between the console and WL Android app, specifically the indoor readings. Temperature is 2 degrees off  and humidity is 7% difference. Updates are set to 15 minutes but changes are not being reflected properly between the two.
Any ideas why this might be happening?
Offline johnd
Re: Discrepancy VP2 and Weatherlink Live
« Reply #1 on: February 11, 2020, 03:27:12 AM »
Well, it's pretty obvious once you consider that the console and WLL each have their own indoor sensors and so will be generating their own readings. Any differences will then be down to differences in positioning of the two units, simple differences in calibration between the two and the well-known issue that the console sensor is well inside the console and therefore prone to slow equilibration and slight heating by any logger that may also be installed, especially network loggers.
Littleport, Ely, Cambs UK
Offline Oilswell
« Reply #2 on: February 11, 2020, 04:45:39 PM »
Thanks for the explanation. I had the two units right beside each other and expected they world be closer. Your point about the console being slow to an equilibrium point makes alot of sense though.
Cheers˘
