Author Topic: 24 HR FARS Wiring  (Read 168 times)
Offline vegaman55
24 HR FARS Wiring
« on: February 06, 2020, 03:24:34 PM »
Does anyone on here have pictures, or could get pictures of the full wiring setup of the 24hr FARS?
Offline Phil23
    • Phil's Backyard
Re: 24 HR FARS Wiring
« Reply #1 on: February 06, 2020, 04:18:37 PM »
See Page 13 onwards in this document.
https://www.scaledinstruments.com/wp-content/uploads/2014/10/R-DFARS_Conversion_V1.2.pdf
I took a different approach with my DFARs conversion.
A 12V 7ah SLA battery, 10 Watt Solar Panel (240x340mm) & charge Regulator.
Then an LM2596 Buck Regulator on the output from the battery.
The Reg has it's output adjusted down to 2.2 Volts & the fan runs pretty well at that.
Bit primitive in taking 12V down to 2.2V, but was basically knocked up with stuff I had on hand.
