Author Topic: My station is working but WU says it is offline ??  (Read 8447 times)
Offline RusstyOfOz
« on: February 04, 2020, 02:32:40 AM »
Hi,  My weatherstation has been showing as offline for a few days now, so I replaced the batteries, did a reset of the outdoor unit and the indoor receiver but it still shows as offline in weatherunderground.  When I check it through IP Tools on my pc it is showing all the current readings so it is obviously working but just not uploading to WU.  I tried a different ethernet cable and a different port in the router but still nothing.
Any ideas what could be wrong?  ](*,)
Offline buffy
  • My PWS: Garni Ventus 830
    • PWS Monitor
Re: My station is working but WU says it is offline ??
« Reply #1 on: February 04, 2020, 03:53:27 AM »
it looks like SSL issue. WU restarted servers today:
All, we made a change just now that we hope helps to solve the SSL issues. If you are still experiencing these, make sure to restart your software/and or device. If after that you are still not getting data please reply. (also reply if it starts working
try report your issue to FB Group:
https://www.facebook.com/groups/145852786027137/
Offline RusstyOfOz
« Reply #2 on: February 04, 2020, 06:54:46 AM »
I have restarted everything but still showing offline.   :-(
(I don't use facebook)
« Last Edit: February 04, 2020, 06:56:18 AM by RusstyOfOz »
Offline boss281
« Reply #3 on: February 04, 2020, 07:43:27 AM »
I'm showing online but updates aren't every 5 seconds on the Web portal. Takes long time to update...
Weather Underground PWS KMDNEWWI3
Offline buffy
    • PWS Monitor
« Reply #4 on: February 04, 2020, 08:04:58 AM »
there is WU active... And sometime answers questions. And also you can report problem there. I don't know any other way to contact them.
Offline RusstyOfOz
« Reply #5 on: February 04, 2020, 08:18:28 PM »
Thanks, I will see what I can do.
Offline RusstyOfOz
« Reply #6 on: February 05, 2020, 06:24:25 AM »
FINALLY!!  =D>  I'm back online!   I have been resetting and rebooting the system for the past 2 days and now it is working again.  HOORAY UU
Offline buffy
    • PWS Monitor
« Reply #7 on: February 05, 2020, 07:34:28 AM »
you have time to fix it, because it will be off again
Offline aulen2002
« Reply #8 on: February 05, 2020, 11:53:12 AM »
Jut noticed that I am showing offline and missing data since Sunday afternoon. Weewx has been running since Saturday (last restart) and is updating other sites. I'm not home to checl the logs though, but still suspect it is a WU issue. Also did not get an email notice that station went offline.
Checking out the facebook group...
« Last Edit: February 05, 2020, 02:05:36 PM by aulen2002 »
Offline konz
    • ArlingtonWX
« Reply #9 on: February 06, 2020, 09:47:41 PM »
Restart weeWX.
