Author Topic: Can I run both Cumulus and Cumulus MX in tandem?  (Read 500 times)
Offline NHSkierGolfer
  • Weather junkie since 1960
    • Bob Hatcher's weather website
« on: January 18, 2020, 03:18:56 PM »
I'd like to try MX if I could.  My AmbientWeather console is connected via USB to the PC.  Can both read from it simultaneously?
BS, Meteorology, 1975 University of Massachusetts at Lowell
MS, Fluid Mechanics and Wind Engineering, 1977, Colorado State University
Offline mcrossley
    • Wilmslow Astro
Re: Can I run both Cumulus and Cumulus MX in tandem?
« Reply #1 on: January 18, 2020, 03:49:25 PM »
No, but they could run alternately. Assuming you have a logger then each instance will catch-up from where it left off.
« Reply #2 on: January 20, 2020, 12:23:18 PM »
OK, thanks, I'll just install it on another computer and use my other console.
Offline PaulMy
« Reply #3 on: January 26, 2020, 12:05:51 PM »
If you have more than 1 console I believe you can run two or more.
On one computer I run Cumulus1 with Envoy/USB, CumulusMX with Vue console/WiFiLogger, and second CumulusMX with Ecowitt GW1000 and start this one from DOS \CumulusMX\CumulusMX.exe -port 8999
Enjoy,
« Last Edit: January 26, 2020, 12:53:40 PM by PaulMy »
Offline mcrossley
    • Wilmslow Astro
« Reply #4 on: January 26, 2020, 12:13:33 PM »
Indeed, as Paul says with two consoles you can run two copies of Cumulus. Though if you run two copies of Cumulus MX on the same computer, then you will have to change the network port as per Paul's message.
« Reply #5 on: January 26, 2020, 04:54:35 PM »
Thanks, guys.  I'll give it a shot.
Offline Tazz 316
« Reply #6 on: May 22, 2020, 07:39:28 AM »
Can't you do this if you also have WLL?
Use MX to pull from WLL and cumulus to pull from your logger.
Offline johnd
« Reply #7 on: May 22, 2020, 07:57:34 AM »
Yes, sure - WLL is essentially just another (albeit enhanced) receiver type. But remember that WLL uses a completely different API from the traditional loggers and so any software taking a data feed from WLL would need to be using WLL-compatible software. So CumulusMX would be OK but not Cumulus for the WLL feed.
Littleport, Ely, Cambs UK
Sorry, but I can't help with individual issues by email. Please post your issue in the relevant forum section here & I will comment there if I have anything useful to add.
