Author Topic: Rain mm reset in the morning instead of midnight in Weather display  (Read 611 times)
Offline teigas
    • Teigen Weather
I have a Davis Vantage vue, i can not change the reset time from the defoult midnight rain reset. The question is if i change the reset time in Weather Display will it be correct in the program ? Or will it reset at midnight because the davis station is doing it? Or will it just record rain data from davis and reset lets say 08 in the morning for an example? Or will it be affected by the davis that stars at 00mm again at midnight?
Offline waiukuweather
Re: Rain mm reset in the morning instead of midnight in Weather display
« Reply #1 on: January 11, 2020, 04:09:31 AM »
as long as you do not have set to use the console rain totals
then you can set the hour to reset the rain in control panel, units, reset time
Offline teigas
    • Teigen Weather
« Reply #2 on: January 12, 2020, 03:31:23 AM »
Okei, thank you!
