Author Topic: Help needed with Saratoga layout left hand margin  (Read 442 times)
Offline grumpazoid
    • Priory Sailing Club
« on: January 08, 2020, 06:41:47 AM »
Hi from a new member.
I am trying to help out with the weather station at my sailing club.
The site used an old version of the script embedded in a wordpress page.
I have updated everything to the latest version and simplified the layout as previous. Everything seems fine except I cannot work out how to remove the left hand margin.
The page is at https://www.priorysc.org.uk/today-at-the-club/
You will see that there is an unwanted scroll bar at the bottom,.
I have compared wxindex.php to the old version that worked and cannot see any difference. I have also looked through ajax-dashboard.php to no avail.
The stand alone pages both new and old respectively are located at
https://www.priorysc.org.uk/wx/wxindex.php
https://www.priorysc.org.uk/Weather/wxindex.php
Offline wvdkuil
  • Wim van der kuil
Re: Help needed with Saratoga layout left hand margin
« Reply #1 on: January 08, 2020, 07:59:23 AM »
Maybe there are more differences, but to get rid of the extra left margin on the dashboard
remove in  wx/weather-screen-blue-narrow.css line 212 (or better set to comment).
Wim
Offline grumpazoid
« Reply #2 on: January 08, 2020, 08:29:39 AM »
Wim,
Thank you for your reply.
I have made that change as suggested but the margin is still there?
It seems to be part of the background.
Offline wvdkuil
  • Wim van der kuil
« Reply #3 on: January 08, 2020, 10:02:30 AM »
Wim,
It is OK,  but the old CSS is still in the browser-cache and it has a long validity.
You have to force reload of the page, right click in an empty part and select reload, or use the menu.
You could test it with another laptop/pc or other browser you did not access the site yet.
The "better" solution is to copy the changed weather-screen-blue-narrow.css and rename it to "narrow.css"
Then change this line (around line 40) in wx/Settings.php from
$SITE['CSSscreen'] = 'weather-screen-blue-narrow.css'; // Default screen 800px designto
$SITE['CSSscreen'] = 'narrow.css'; // Default screen 800px design
It is a new css-name for the browser, so it will load the css and all should be well.
Wim
Offline grumpazoid
« Reply #4 on: January 08, 2020, 10:26:19 AM »
Brilliant....I deleted browser cache and it does now indeed display correctly.
Much appreciate your help.
Roopz
