Author Topic: Customized Server Settings  (Read 9336 times)
Offline chicoDaMan
« on: January 06, 2020, 01:44:30 PM »
UPDATE:  I did end up buying a GW1000 as advised. It works well with my WS-1400-IP.
The WS View Android/iOS software is kinda funky, had to switch between two Android and two iPhone devices to get through all the menus without hanging or crashing...but stubbornness finally won out.
Indeed, they used an ESP8266 chip inside the device, as I suggested above. Nice chip for this type of application, and while the Android/iPhone software may be of poor design, it appears the device firmware is solid and stable. That's all that matters, really...
Question (please advise me if I should start a new thread for this...): I've seen a few threads that indicate there is a custom menu in the WS View software that would allow one to send data to PWSweather or other servers. I cannot find such a menu on my WS View version...is there a trick to access this menu, or did I misunderstand something?
Thanks for the advice regarding the GW1000...
Re: Customized Server Settings
« Reply #1 on: January 06, 2020, 03:41:43 PM »
Ecowitt "Customized Server" upload settings is reached within the WS View app.
Open WS View:
- Select your device
- More
- Weather Services
- press Next until you get to "Customized"
- There you fill in the fields and select the correct protocol type (Ecowitt or WU depending on service)
You can only configure these fields for one customized server.  If you want to expand beyond just the one customized server location then I suggest you expand your weather station hardware/software to include some other 3rd party software like: Cumulus MX, Meteobridge, Weather-Display, or WeeWx. The best way to support 3rd party software is by adding the GW1000 and then adding the 3rd party software to some other device.
There are other things you can do with Customized server settings besides these listed below.
PWSweather
Protocol type: WU
Server:
pwsweather.com  or
www.pwsweather.com
Path:
/pwsupdate/pwsupdate.php?
Station ID: Your account station ID
Station Key: Your password (changing to a key soon)
Port:
80
Upload Interval:
(not less than 60 seconds. Also 300 seconds (5 minute) is very adequate too)
AWEKAS
Protocol type: WU
Server:
ws.awekas.at
Path:
/weatherstation/updateweatherstation.php?
Station ID: Your account username (NOT YOUR STATION ID)
Port:
80
Upload interval:
300 seconds: for free account
60 seconds: for free AWEKAS plus accounts only after you click to accept the agreement
Less than 60 seconds: for paid AWEKAS Stationsweb subscription accounts
« Last Edit: February 09, 2021, 11:06:09 AM by galfert »
Offline chicoDaMan
« Reply #2 on: January 06, 2020, 04:07:14 PM »
Thanks, nice instructions. Didn't know how to find that menu, but it's right there when you know where... ;)
Offline darb81
« Reply #3 on: March 03, 2020, 02:39:00 PM »
I've entered in the details to upload my w
PWS data to PWSweather, how long should it take for PWSweather to start receiving data?
Offline darb81
« Reply #4 on: March 04, 2020, 01:56:39 AM »
Here is a screen shot of the details I entered in the customized server settings just to make sure I entered them correctly  http://imgur.com/gallery/0x3fuGW
In the key field I entered my log in password for pwsweather web site, I didn't leave it blank.
Offline pedum
    • None
« Reply #5 on: March 07, 2020, 02:58:14 PM »
Thank you for posting the image of your custom configuration for pwsweather dot com. I used it, and had no problems at all getting data from my ECOWITT GW1000 and connected sensors uploaded to pwsweather dot com.
Thanks again,
Bob
Offline hcourtois
    • Meteo La Bourgonce
« Reply #6 on: April 15, 2020, 05:17:46 AM »
Hello,
I have a Misol HP2550 station. There is the Server Customized option.
I wish to send my data to Awekas.
How to configure the HP 2550?
Thank you
Bonjour,
J'ai une station Misol HP2550. Il y a l'option Server Customized.
Je souhaite envoyé mes données sur Awekas.
Comment configurer la HP 2550 ?
Merci
Protol Type :  Same  ???
Ip / Hostname :  ??
Port : ??
Intervall : 330 s ??
Offline etaf
    • PWS - ewittW8686etaf
« Reply #8 on: June 13, 2020, 08:29:07 AM »
can the MET WOW settings , be used for any other weather feed, are the protocols the same as say AWEKAS
« Reply #9 on: June 13, 2020, 12:52:09 PM »
Not sure I understand what you are asking. There are only two parameters requested by the WOW settings in FO clones...the ID and the Key. How is that going to allow you to "be used for any other weather feed?"
To your other question, the WOW upload protocol is similar in construction to the WU protocol that AWEKAS does use. But I don't see how that is relevant unless you are coding your own upload script, which is out of the scope of this thread in discussing the "Customized" server upload settings.
Offline etaf
« Reply #10 on: June 13, 2020, 04:22:58 PM »
thanks, yep, its in the firmware to goto the website, shame , don't see much value in the WOW site
« Reply #11 on: June 13, 2020, 04:39:38 PM »
Interesting to hear that (you don't care for it) as someone in the UK. When you look at the WOW map it is jam packed with stations in the UK. Seems obvious since it is a UK site. But the fact that it is so much more densely populated on the map in the UK led me to believe that it must be a popular goto source for for weather information by UK people. I have not found much to like either so I thought I must be missing something. Maybe there are a bunch of cheap stations sold over there that only report to WOW? Your comment has left me perplexed.
Offline etaf
« Reply #12 on: June 13, 2020, 05:20:14 PM »
I signed up because of the Brand in UK and the unit allows, so signed up to all
BUT i find it clunky to navigate, and when compared to the info available from the other sites, not my usual goto site over the last few days.
maybe i'm missing something
A lot of the sites listed locally are also on the other sites also
plus i got a lot of
Our services aren't available right now
in the beginning , so didn't bother going back
« Last Edit: June 13, 2020, 05:22:41 PM by etaf »
Offline RusHii
    • Meteo41
« Reply #13 on: June 21, 2020, 01:47:36 PM »
Hello,
I would like to have more information before buying a HP2551 (= HP1000SE PRO from Froggit), the most imortant things is to send the weather station data to my own server. In the manual we can customize server setting (IP, port, interval, protocol) but I didn't see anything about the path to set my API path. So can we set the path or the protocol do everything ?
Thanks for your answer !
RusHii
HP1000SE PRO - www.meteo41.fr
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
« Reply #14 on: June 21, 2020, 01:58:09 PM »
Hi!
Yes, you can change the path. Both for WU and Ecowitt. But there's only ONE custom server. So you have to decide: WU or Ecowitt to ONE target.
Regards, Oliver
Offline RusHii
    • Meteo41
« Reply #15 on: June 21, 2020, 01:59:08 PM »
Thanks but what is this interface ? Is it an external app ?
Offline olicat
    • FOSHKplugin
« Reply #16 on: June 21, 2020, 02:02:22 PM »
Hi!
Yes, this is WS View under Android: https://play.google.com/store/apps/details?id=com.ost.wsview
This should also work with the HP2551 (HP1000SE PRO from Froggit).
Oliver
« Reply #17 on: June 21, 2020, 02:04:30 PM »
That is the mobile app interface on managing the HP2551 display console. It is called WS View (free from FO/Ecowitt). It is available only for Android and iOS. It is also used to flash WiFi firmware updates to the HP2551 display console.
Offline RusHii
    • Meteo41
« Reply #18 on: June 21, 2020, 02:19:45 PM »
Offline ilikourou
« Reply #19 on: May 29, 2021, 01:34:37 PM »
PWSweather
Protocol type: WU
Server:
pwsweather.com  or
www.pwsweather.com
Path:
Port:
80
Upload Interval:
Hello,
The guys from PWSweather informed me that the new server settings should be:
Server   www.pwsweather.com
Path   /api/v1/submitwx? (make sure you include the ?)
Station ID   The station ID you selected
Password   Your station's PWSweather.com API key
Port   80
However, I tried using the above settings and I could not make it work. Using the settings you provided ("/pwsupdate/pwsupdate.php?" for path) seems to be working, but the team from PWSweather told me that they are going to discontinue the old path.
Has anyone here managed to make the new path work?
Ilias
Offline olicat
    • FOSHKplugin
« Reply #20 on: May 29, 2021, 01:52:09 PM »
Hi!
At least I tested this via web browser and it does work:
https://pwsupdate.pwsweather.com/api/v1/submitwx?ID=YOURID&PASSWORD=YOURPASSWORD&dateutc=2021-05-28+19:51:13&action=updateraw
and also
http://pwsupdate.pwsweather.com/api/v1/submitwx?ID=YOURID&PASSWORD=YOURPASSWORD&dateutc=2021-05-28+19:51:13&action=updateraw
Just use your credentials and try this link in your web browser.
Regards, Oliver
Offline ilikourou
« Reply #21 on: May 29, 2021, 02:00:22 PM »
Hello, thanks for the quick reply.
First of all I should mention that I need to use the settings above in "WS View" app, to send the weather data from my Froggit PWS.
Secondly, the link you provided is https://pwsupdate.pwsweather.com... whereas they instruct that the server should be pwsweather.com... (without "pwsupdate." in the beginning).
Third, in the PASSWORD section of the URL you provided I guess I should enter my API key, right? The JSON respond I am getting is just the following:
error   null
success true
Thanks again,
Ilias
Offline olicat
    • FOSHKplugin
« Reply #22 on: May 29, 2021, 02:59:13 PM »
Hi!
Without pwsupdate you will get to their www-page and not to the API-endpoint. So they are having technical problems with the redirection currently or they were wrong with this information. Perhaps you should ask again.
error   null
success true
Sounds good to me: 0 errors; successfull.
Then you should try this:
Enable
Protocol: Wunderground
Server: www.pwsweather.com
Path: /pwsupdate/pwsupdate.php?
Station ID: PWSWeather-ID
Station Key: PWSWeather-Key
Port: 80
Interval: 300
or:
Enable
Server: pwsupdate.pwsweather.com
Path: /api/v1/submitwx?
Port: 80
Interval: 300
Apparently, the upload interval can now also be >= 60 seconds: https://www.pwsweather.com/frequently-asked-questions#how-often-should-i-post-to-the-pwsweather-servers (search for often).
Regards, Oliver
Offline ilikourou
« Reply #23 on: June 04, 2021, 12:58:29 AM »
Enable
Port: 80
Interval: 300
Hello, it seems that the settings above are absolutely correct and everything works as expected.  [tup]
I contacted PWSweather support and they confirmed that the settings they provided in the first place (with "pwsweather.com" as server) were incorrect.
Thank you for the help!
Offline gwatuk
« Reply #24 on: August 08, 2022, 11:22:22 AM »
Just thought I'd post the settings that I've just used (I think slightly different from the above).
This is from an Ecowitt gateway Version: GW1100A_V2.1.7
Enable
Path: /weatherstation/updateweatherstation.php?
Port: 80
Interval: 60
Hope that might help 8-)
