I got a real nasty problem going on and need some ideas, for some reason my uv reading goes to zero after a couple hours of working ok in the am. Now i changed the uv sensor, iss and console with data logger but no joy. I use weather display software and when i restart it the uv shows for a few seconds then quits. So i broke out the spare iss and set up separate station and it is doing the same thing, this is on a different computer and wd program. Now both consoles show the uv readings just fine, can not figure out how two separate set ups can do the same thing, it is just too weird to figure out. All other readings are fine and my uv has been working just fine for years.
