Author Topic: My webcam not showing up  (Read 1923 times)
Offline Michael M
    • http://mypensacolaweather.com
Re: My webcam not showing up
« Reply #50 on: November 17, 2019, 10:00:47 PM »
Looks Great! Sam
I like that a lot
Your welcome for the help
My pleasure to help you out with your camera
WU
KFLPENSA29 is currently offline
Sending 17 year old station back to be refub
[AKA]  Michael
Offline davidmc36
    • IONOTTAW14
« Reply #51 on: February 01, 2020, 05:33:16 AM »
I dont know what is going on over there now. My camera was MIA for  months. Not even able to see history. Then there was a period of maintenance to the add camera or device section. When that was over, it showed colored spinner on camera tile.....just spinning.......forever.
Then the tile just seemed blank but able to click and go to historical pics.
I have tried every connotation of webcam.wunderground, 53. Etc. Etc. IP address, Port/Pasv, even deleted and added new CAM to try password.......nothing........always fails login.
Offline Michael M
« Reply #52 on: February 01, 2020, 09:54:43 AM »
What Kind of Camera is it?
Are you using BI to upload or is it straight from the camera
Has it ever worked before?
« Last Edit: February 01, 2020, 10:03:18 AM by Michael M »
WU
[AKA]  Michael
Offline awsum140
« Reply #53 on: February 01, 2020, 10:04:46 AM »
If it fails login your credentials aren't correct.
If it's not a Boerboel it's just a dog.
KNJSOUTH86
Offline Michael M
« Reply #54 on: February 01, 2020, 10:05:23 AM »
That's what im thinking too
And im waiting for him to come back online
« Last Edit: February 01, 2020, 10:07:05 AM by Michael M »
WU
[AKA]  Michael
Offline Michael M
« Reply #55 on: February 01, 2020, 10:09:22 AM »
The Email notification is a little slow after the crash last month
WU
[AKA]  Michael
Offline Michael M
« Reply #56 on: February 01, 2020, 10:28:10 AM »
Sometimes different cameras require that you use for IP Address the ftp://52.36.136.128/
Some do not require the ftp://
Always make sure the port is set to 21
Make sure the user name is correct
The password has to be exact upper case and lower case
Also some cameras automatically put filename on the image being sent to WU
The WU will reject images with file names so you must remove file name if you have that option
if not then you have to you a software to upload with out file name
Blue Iris is a good software to upload to WU
Hope this helps
« Last Edit: February 01, 2020, 10:32:19 AM by Michael M »
WU
[AKA]  Michael
Offline Michael M
« Reply #57 on: February 01, 2020, 10:32:48 AM »
There you are
You are back
Try these setting and let me know if that helps
Also what is your WU station ID?
« Last Edit: February 01, 2020, 10:34:59 AM by Michael M »
WU
[AKA]  Michael
Offline davidmc36
    • IONOTTAW14
« Reply #58 on: February 01, 2020, 10:39:55 AM »
It is Foscam FI9900P.
Was working fine before.
File name is off.
Have tried copy/paste and manual punch in for User and PWD, multiple times.
Camera interface rejects address w/out leading ftp
Once address is accepted, the login fails
Camera is able to FTP load to Webcam.io with no issues.
Have tried all those settings over and again.
Offline davidmc36
    • IONOTTAW14
« Reply #59 on: February 01, 2020, 10:40:36 AM »
IONOTTAW14
Offline Michael M
« Reply #60 on: February 01, 2020, 10:42:24 AM »
ok
Do you mind if I log in to your pc with TeamViewer and take a look at your setting?
WU
[AKA]  Michael
Offline Michael M
« Reply #61 on: February 01, 2020, 10:47:10 AM »
If you are ok with me logging into your PC with TeamViewer then just message me the user id and the password
don't post it on the forum Please
If not I understand
« Last Edit: February 01, 2020, 10:51:04 AM by Michael M »
WU
[AKA]  Michael
Offline Michael M
« Reply #62 on: February 01, 2020, 11:02:23 AM »
Does it show in the WU devices online or offline?
WU
[AKA]  Michael
Offline davidmc36
    • IONOTTAW14
« Reply #63 on: February 01, 2020, 12:27:09 PM »
Shows off line. Not home now. Maybe in a couple hours or something.
Offline davidmc36
    • IONOTTAW14
« Reply #64 on: February 02, 2020, 09:35:10 PM »
I logged on from my Tab with the credentials I sent in PM.
Works a treat.
