Author Topic: WeatherCat hanging  (Read 3115 times)
Offline rrsum
WeatherCat hanging
« on: October 17, 2019, 11:03:38 AM »
I've had my weather station (Davis Pro2 with Envoy) up and running for 7 years and have never had a problem.  The software is WeatherCat running on an iMac.  All of a sudden I'm getting strange results.  The WeatherCat gauge window reports a communications error and hangs, so I have to force quit the software, and when restarted, it seems to run fine for a day or so. (It's as if the envoy is pulling an interrupt, but not giving any data up to the software.)
I looked in the data and here are some suspicious lines:
23476 t:170716 T:7.44 Ti:16.83 D:5.42 Pr:1001.1819 W:11.27 Wd:270 Wc:5.34 Wg:24.14 Ph:0.00 P:3.56 H:87 Hi:58 S:0 U:0.0 Pm:49.79 Py:720.86 Ed:0.00 Em:0.00 Ey:0.00 Sy1:0.00 Sy2:0.00 Sy3:0.00 Sy4:0.00 Sy5:0.00 C:"N/A" V:4
23506 t:170746 T:7.44 Ti:16.83 D:5.42 Pr:1001.1819 W:11.27 Wd:270 Wc:5.34 Wg:24.14 Ph:0.00 P:3.56 H:87 Hi:58 S:0 U:0.0 Pm:49.79 Py:720.86 Ed:0.00 Em:0.00 Ey:0.00 Sy1:0.00 Sy2:0.00 Sy3:0.00 Sy4:0.00 Sy5:0.00 C:"N/A" V:4
23536 t:170816 T:7.44 Ti:16.83 D:5.42 Pr:1001.1819 W:11.27 Wd:270 Wc:5.34 Wg:24.14 Ph:0.00 P:3.56 H:87 Hi:58 S:0 U:0.0 Pm:49.79 Py:720.86 Ed:0.00 Em:0.00 Ey:0.00 Sy1:0.00 Sy2:0.00 Sy3:0.00 Sy4:0.00 Sy5:0.00 C:"N/A" V:4
23566 t:170846 T:7.44 Ti:16.83 D:5.42 Pr:1001.1819 W:11.27 Wd:270 Wc:5.34 Wg:24.14 Ph:0.00 P:3.56 H:87 Hi:58 S:0 U:0.0 Pm:49.79 Py:720.86 Ed:0.00 Em:0.00 Ey:0.00 Sy1:0.00 Sy2:0.00 Sy3:0.00 Sy4:0.00 Sy5:0.00 C:"N/A" V:4
I don't know what the Sy1 - Sy5 indicate, but they don't appear on other lines.
I've replaced batteries in the weather station itself and in the envoy (which also has plug power).
One can see strange activity on some of the graphs on my weather page.
Has anyone seen this kind of problem and are there any suggestions as to how to fix it?
--Rick
http://www.timberhillassociation.org/weather/
Offline iccb
    • Säätilanne Eurassa
Re: WeatherCat hanging
« Reply #1 on: October 17, 2019, 12:44:00 PM »
You can check from Tools -> Live data to see if there is some sensor errors..
You can also install newest USB uart drivers for datalogger...
Offline rrsum
« Reply #2 on: October 17, 2019, 01:34:08 PM »
I had updated the uart a year ago when I updated my iMac.  I'll monitor the live data if/when this problem continues.  Thanks for the suggestion.
--Rick
Offline rrsum
« Reply #3 on: October 18, 2019, 11:00:21 AM »
No sensor errors reported on the last hang.  Same situation, WeatherCat hangs, but restart after a force quit fixes the problem.  Any other suggestions?
--Rick
« Reply #4 on: October 18, 2019, 12:09:31 PM »
Try a different computer?
Offline rrsum
« Reply #5 on: October 20, 2019, 11:33:47 AM »
Well, I decided to simply reboot the iMac.  It had been acting a bit strange - wouldn't sleep at all, nor would it go into the screen saver.  After rebooting, the weather station problem has not occurred.  It seems like this problem was an OS problem and not a weather station nor WeatherCat problem at all.  Thanks for the suggestions.
--Rick
Offline waiukuweather
« Reply #6 on: October 20, 2019, 01:28:19 PM »
sometimes a bigger hammer does help
