Author Topic: Weatherlink shuts down.  (Read 999 times)
Offline arrowspace90
  • Vantage Pro II, tripod mount, 30 feet elevation
« on: October 11, 2019, 01:31:28 PM »
I have a new Vantage Vue at my other house about 15 miles away from my residence.  It reports to WL via a data logger (a new one).
3 times now, the station has stopped reporting because WL either closed or crashed.  The capable desktop computer there has been set to never go into sleep mode.
It's running Windows 10.
What setting, or whatever, can be causing this to happen?  I have the same setup here at my residence for my Davis Pro II.  I have the WL software here and Windows 10.  I am protected here against computer shutdowns because I also have a Meteobridge box that intercepts the wireless reporting station and puts the data on the Internet.
However, even though this computer at residence goes into sleep mode, the WL software has not just stopped running.
Offline the beteljuice
  • the beteljuice
    • test site
Re: Weatherlink shuts down.
« Reply #1 on: October 11, 2019, 04:44:05 PM »
The dreaded update crawl and re-boot, even if you think you've found a way say NO ?
Offline sho23
  • Meep
« Reply #2 on: January 07, 2020, 05:20:12 PM »
We run a batch file that checks and relaunches WL if it hangs/closes itself every X minutes. So sometimes i go in the office and see 4-5 dead duplicates and 1 WL running well. haha.
Offline davidmc36
  • Morewood Ontario Canada
    • IONOTTAW14
« Reply #3 on: January 07, 2020, 06:27:44 PM »
I did the same with a laptop at model plane field since the Cell stick would knock off after about two days. Dropped a batch file onto it and hit the go button. Reboot every 24 hours.
Offline rob.quick
« Reply #4 on: February 14, 2020, 04:13:47 PM »
I'm having exactly the same issue as the OP ! I've tried 3 different computers with two different weather stations (Vue and Pro2) and the issue still persists, the only constant bit of hardware is the USB/weatherlink cable between the console and my PC.
Any idea what the cause is ?
How would I run a 'batch' file ?
Any help appreciated.
« Reply #5 on: February 14, 2020, 04:40:27 PM »
Offline rob.quick
« Reply #6 on: February 14, 2020, 04:50:12 PM »
Here's a full build of 6.0.3 should you choose to try another.
http://toolbox.davisnet.com/downloads/weather/software/WL_6_0_3_fullinstall/6_0_3_full_install.zip
Are you suggesting the issue is caused by my 6.0.3 software ??
« Reply #7 on: February 14, 2020, 05:02:31 PM »
I have no idea. I merely offered this option should you wish to try. Perhaps your WL has become corrupt somehow.
« Reply #8 on: February 15, 2020, 04:31:28 AM »
This thread is becoming slightly confused - it's not obvious as to the exact issue that different posters have. IME a outright crash of WL for Windows is very rare indeed (unless eg one of the settings files has somehow got corrupted), although of course there will be no automatic restart of WLfW if Windows has decided of its own volition to close Weatherlink and run a Windows update.
It's always worth looking for a text file called download.log in the Weatherlink folder which keeps a log of attempted download actions and issues - this often gives a clue as to the cause.
If the issue is that communication has dropped out with a USB logger then this is a well-known issue with a variety of possible fixes.
Littleport, Ely, Cambs UK
Offline rob.quick
« Reply #9 on: February 15, 2020, 12:52:11 PM »
Hi Johnd,
Apologies, I should have been clearer as to what my specific issue was. In summary the WL software on my PC closes down without me physically closing it down. This has continued to happen on various different PC's with 2 different Davis weather stations.
I've looked and can't find the download.log you mention ?
If the communication had dropped out with the USB logger surely that would not cause the WL software to close down ?
To clarify my issue is identical to the OP, any help to resolve would be appreciated.
Offline sho23
  • Meep
« Reply #10 on: March 09, 2020, 03:19:29 PM »
You can also do Ctrl+L in Weatherlink to pull the download log.
« Reply #11 on: March 09, 2020, 05:00:08 PM »
Take this for what it's worth as I am not programmer, software developer etc.
I used WL exclusively for many years. Out of the blue it would either shut down or get some error like it was 200 degrees F. Could never figure out why but it would go back to working just fine after restarting and correcting errors. Then the inevitable error would show up again and stop working.
I finally gave up on it and went to Cumulus. I can only count 1 time that Cumulus shut down.
I just think it's old software that needs to be canned and and new version should be developed.
But, Davis is in the hardware business, not software so I think they will just keep adding more features like WL.com, expansion modules etc.
 I will say that since now  I use the wifi logger I just start it up once a week to download data then shut it down. Have always liked the WL graphs.
Just my 2 cents.
« Reply #12 on: March 09, 2020, 06:21:31 PM »
Same here.  I used Startwatch (now free) to restart it.  But since moving to Meteobrdige I no longer have an uptime issue.
