Author Topic: Saratoga Templates Meteobridge FTP & Weather Data Status Not Current  (Read 619 times)
Offline lobsterman
    • Cape Small Harbor Weather
I know I have solved this once before but cannot recall how to resolve the Not Current status notice.
Saratoga Templates with data from Meteobridge NANO SD
I have run the reload template which gives a positive response.
My templates are all updated to latest versions.
Offline hymrog
    • NewAlbanyWeather
Re: Saratoga Templates Meteobridge FTP & Weather Data Status Not Current
« Reply #1 on: September 05, 2019, 08:29:20 PM »
Hello
What does your live data page report for your FTP uploads?  Are you using the correct credentials? Also, are able do a test FTP upload successfully?
g
« Reply #2 on: September 05, 2019, 09:59:13 PM »
I think it's an FTP issue (either not successfully completing or uploading to the wrong directory?)
The MBtags.php?sce=view on your site shows:
$WX['date'] = '2019-07-02'; // local date
$WX['time'] = '06:30:31'; // local time
so it hasn't been uploaded for a while.  Make sure the template (for the MBtags.php file) in Meteobridge uses
https://suiattle.net/CapeSmallHarborWeather/mbridge/gen-MBtags.php
Although.. if your Meteobridge software is an older version (which didn't support https for templates), you might have to allow
http://suiattle.net/CapeSmallHarborWeather/mbridge/gen-MBtags.php as the template by turning off the redirect to https for your site temporarily, have meteobridge reload the template, then turn on the https redirect again.
Offline lobsterman
« Reply #3 on: September 07, 2019, 04:05:14 PM »
FTP test upload works fine.
The "Reload Template" gives: "Info (Event #04): Download of template went fine"
The NANO SD supports https, unlike the Meteobridge version on a TP-3020, for example.
I'll try turning off https and see what happens.
Offline lobsterman
« Reply #4 on: September 07, 2019, 05:21:52 PM »
Nada. I cannot get the Not Current status to change with https redirect off. [ You are not allowed to view attachments ]
Is there an FTP_LAST_UPLOAD flag set somewhere I can delete?
The FTP does a test upload correctly to the correct folder.
« Reply #5 on: September 07, 2019, 08:38:32 PM »
According to your Settings-weather.php the MBtags.php file is supposed to be at https://suiattle.net/CapeSmallHarborWeather/mbridge/MBtags.php but doing ?sce=dump on that URL shows
which is why the wxstatus.php page shows the stale data
Meteobridge FTP    NOT Current    1622:05:56    > 0:05:15
02/07/2019 06:30
Meteobridge weather data    NOT Current    1622:05:56    > 0:05:15 02/07/2019 06:30
Since the FTP is showing success, either the folder the file is being uploaded to or/and the filename is not MBtags.php, so check the FTP settings for correct path/filename.
Offline lobsterman
« Reply #6 on: September 08, 2019, 09:42:14 AM »
02/07/2019 06:30
Pretty odd. I had all the paths correct and test upload working fine. The old FTP username/pwd combo worked fine when using FTP at the terminal but it had a double quote in it. Finally I went and changed the FTP username's password.
Changing the password seems to have solved the problem.
Thanks for your patience and help.
