Author Topic: Increase your 2902 range in ten minutes, at no cost  (Read 1929 times)
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
« on: August 25, 2019, 05:09:03 PM »
Here's an easy mod to increase the array-console range. It's merely straightening out the console antenna to increase it's efficiency.
I'll do some testing tomorrow to see how much of an improvement it is, but I'd guess 20% to 35%.
First, make sure you have the right tools, specifically a small diameter jeweler's screwdriver for phillips. The lower two screws have a small diameter access shaft. If you can't unscrew these screws Amazon is your friend.
To start remove the batteries, all five screws and break the case open with your fingernails.
Picture 1: [ You are not allowed to view attachments ]
See how the red antenna wire on the right is curved over? A required mechanical compromise for a poor RF design element. You can also see where I have drilled the hole. I started with a 1/16" drill and then used a 5/64"
Picture 2: [ You are not allowed to view attachments ]
The antenna now routed through the hole. If I did it again I would drill the hole a bit further to the right.
Picture 3: [ You are not allowed to view attachments ]
How the console looks with the completed mod.
My example is a WS-1900, but it's just a 2902 with the WiFi removed. Otherwise identical.
« Last Edit: August 25, 2019, 08:27:36 PM by WA4OPQ »
Offline WA4OPQ
Re: Increase your 2902 range in ten minutes, at no cost
« Reply #1 on: August 25, 2019, 05:54:48 PM »
I moved my array 40 feet further away, to a location that didn't work before. It's receiving fine on the console.
I'm pleased.
Offline the beteljuice
  • the beteljuice
    • test site
« Reply #2 on: August 25, 2019, 06:52:58 PM »
Seems to be plenty of space in the case, why not just double the length ? - of course you can still add a little bit on externally.
Remember the little transistor radio telescopic aerials ...
Imagine what you will KNOW tomorrow !
Offline WA4OPQ
« Reply #3 on: August 25, 2019, 07:02:45 PM »
At 915 MHz the optimum length is 78mm, 3.07"
« Reply #4 on: August 25, 2019, 07:04:37 PM »
If I recall back in my CB days, this is the way to go as it's a more efficient wavelength of antenna (i.e. making a 1/4 wave to a 1/2 wave).
Offline WA4OPQ
« Reply #5 on: August 25, 2019, 07:10:31 PM »
An external center-fed half-wave antenna would be more efficient, but it's no longer a ten minute project.
« Reply #6 on: August 25, 2019, 07:16:16 PM »
At quarter wave.
« Reply #7 on: August 25, 2019, 08:45:44 PM »
You could probably create a dipole by soldering on another equal length antenna wire to the ground point closest to the antenna point and have it point in the opposite direction (down). A dipole antenna increases the gain.
I can't tell from the pictures but is the black wire possibly already there acting as the dipole?
« Last Edit: August 25, 2019, 08:47:18 PM by galfert »
Offline WA4OPQ
« Reply #8 on: August 25, 2019, 09:02:56 PM »
The red wire is a 1/4 wave antenna using the circuit board as a ground plane, similar to an antenna sticking up in the center of the roof of a car.
A 1/2 wave dipole is fed at the center, so it would involve running small coax from the circuit board out to the insulated center of a 6.14" piece of wire.
I chose the simplest solution. If I still needed more gain I'd add a yagi to the array. Which I may still do.
Offline WSWeather
« Reply #9 on: August 25, 2019, 10:21:24 PM »
Did this change the rssi indication ("number of bars") on the console?
Offline WA4OPQ
« Reply #10 on: August 25, 2019, 10:46:53 PM »
It went from 3-4 bars to 5.
Offline DaleReid
    • Weather at Eau Claire, WI
« Reply #11 on: August 25, 2019, 10:51:16 PM »
Is the transmitter vertically or horizontally polarized?
ECWx.info
ECWx.info/t/index.php
Offline WA4OPQ
« Reply #12 on: August 25, 2019, 11:19:48 PM »
The antenna in the array is vertically polarized.  It's been helically shortened.
Offline ghulse
« Reply #13 on: October 19, 2023, 07:00:37 PM »
I know this is an old thread. Will this hack work on a WS-2000?
Offline Gyvate
« Reply #14 on: October 19, 2023, 07:35:44 PM »
it should also work with a HP25x0, WS-2000/WS-5000 console where already changing the antenna wire location from horizontal to vertical without the hole should give a better reception (there are even little brackets on the left hand side [with the display down] to hold the wire). Has already been done several times with significant reception improvement
Offline ghulse
« Reply #15 on: October 21, 2023, 11:32:22 AM »
The company must have modified its design. I opened up the case on the WS-2000 this morning, and this is what I saw. The antenna wire is already straight. I guess there's no longer a quick fix to improve reception?
« Last Edit: October 21, 2023, 11:33:57 AM by ghulse »
Offline Gyvate
« Reply #16 on: October 21, 2023, 12:57:46 PM »
other than attaching an outside (the housing) antenna probably no.
There have been such antenna modifications for the HP"550/WS-2000/WS-5000 and the WS-2902 consoles reported and documented here in the forum.
