Author Topic: Home Weather Station Cumulus Version and upgrading  (Read 536 times)
Offline Phil23
    • Phil's Backyard
« on: July 09, 2019, 05:44:49 AM »
just beware if you are using a version prior to March 2019 then its imperative to do a fresh install
I may have fallen into this trap.
Mine was certainly pre-2019 & things went a little pear shaped when I tried to update it a few days ago.
Downloaded the PWS folder before I tried, but when I restored it I still looked partially broken.
Also tried installing a new copy in /pwsnew, but it didn't seem to want to work alongside the restored copy in /pws.
Unusual thing I notice now with the restored copy is it still shows Copyright 2019, even though it's probably 12 months + old.
Cheers.
PS.
What's restored is here...
http://weather.inverellit.com/pws
Assume it's best to start afresh. But do I need to do anything about deleting the hosted database?
Offline Phil23
    • Phil's Backyard
Re: Home Weather Station Cumulus Version and upgrading
« Reply #1 on: July 10, 2019, 04:55:19 PM »
Now have a fresh install running at http://weather.inverellit.com/pwsnew
Only issue I now have is that the sun position panel is blank.
When I refresh with the developer mode open I see an error 500 in loading sun3.php.
Anyone got any suggestions on how I resolve this?
Phil.
« Reply #2 on: July 10, 2019, 05:23:20 PM »
I split off this to a new topic, since you're using the CU-HWS from my distribution. (The Cumulus version).
I think the problem with the sun3.php page is your timezone entry of 'Sydney' -- that's not a recognized timezone from here.  Use easyweathersetup.php and change it to
Australia/Sydney and it should work again.
Offline Phil23
    • Phil's Backyard
« Reply #3 on: July 11, 2019, 05:59:00 AM »
Thanks!
Fixed it in one.
Will move it where it belongs now.
Test copy sitting currently at http://weather.inverellit.com/pwsnew
Cheers.
Offline Phil23
    • Phil's Backyard
« Reply #4 on: July 11, 2019, 07:04:32 PM »
Regard the Sun position bearing setting, is the value somehow directly related to latitude.
Comparing the Elevation & Azimuth with http://suncalc.org @ my latitude of -29.81, I found a setting of 50 to give me a more correct result that 100.
I can simply keep experimenting, but just wonder if I can also come up with the right number thru a simple calculation.
Cheers
Phil
Offline Phil23
    • Phil's Backyard
« Reply #5 on: July 12, 2019, 05:04:01 PM »
Should add,
I presume the sun position calc already uses my latitude,
but am a bit curious about a more detailed explanation of what the fine tuning parameter does.
Cheers
Offline Phil23
    • Phil's Backyard
« Reply #6 on: July 13, 2019, 07:02:57 PM »
Slowly working my way thru setups & getting results.
I notice that the page completely reformats when viewed on phones etc;
That looks really good!
Wondering how to improve the Webcams though.
I've setup 2, East & West, and made Webcam1 & 2.php & added those in the menu.
They look fine on the PC, but have the right side of the popup cropped when viewed on a mobile device.
Does this mean that somewhere there is a setting that can be changed to use webcamsmall.php on mobile pages?
Edit:- My setup is sitting here....  http://weather.inverellit.com/pwsnew
Phil.
