Author Topic: Help with Saratoga template and standalone page  (Read 685 times)
Offline txweather.org
    • Texas Weather
« on: June 30, 2019, 11:54:30 PM »
I have this page https://www.txweather.org/wxrecordsalltime.php I am using standalone mode and I have gave it the file path to testtags which is located under WDL/testtatgs.php
The issue is that the pages does not seem to find the file. Any ideas what I have done wrong?
Thanks!
    • Texas Weather
Re: Help with Saratoga template and standalone page
« Reply #1 on: July 01, 2019, 10:37:06 AM »
BumP! :)
Online wvdkuil
  • Wim van der kuil
« Reply #2 on: July 01, 2019, 12:02:54 PM »
Thanks!
Without the source of thescript it is difficult to check.
Normally adding sce=view displays the script, but not in this case https://www.txweather.org/wxrecordsalltime.php?sce=view
The output is  File: MBtags.php
Are you sure that testtags.php is the one used?
Wim
Support for Leuven-Template & Scripts  at this forum
Support for the PWS_Dashboard (HWS-template) for WD a.o.  https://pwsdashboard.com/
Script sponsors https://support.leuven-template.eu/userlistScripts.php
Template sponsors https://support.leuven-template.eu/userlist.php
Offline Jasiu
    • LexMAWeather
« Reply #3 on: July 01, 2019, 12:27:24 PM »
Wim
This will happen if the MBtags.php include is in the file before the download code. The same parameter is examined in MBtags, so it executes there and then exits - and the download code for the page isn't reached.
    • Texas Weather
« Reply #4 on: July 01, 2019, 01:00:58 PM »
I created a pastebin with the code and my edits.
I removed all calls to settings.php but it still somehow pulling MBtags.php which is very confusing.
I cant find where is calling it from... Maybe from the top/headers/common.php?
Is also confusing because I am declaring my wxtags on the file so why is still pulling it from the site it self... :?
https://pastebin.com/Pf7N0XVr
Online wvdkuil
  • Wim van der kuil
« Reply #5 on: July 01, 2019, 01:21:59 PM »
Thanks!
Your are running a saratoga page.
The $SITE['WXtags'] are included in top.php, based on your settins.php and settingsweather.php => MBtags.php
You defined in your script
$WXtags  =  './WDL/testtags.php';
But the $WXtags is not used anymore in the script
There should be an include $WXtags;  also.
Wim
    • Texas Weather
« Reply #6 on: July 01, 2019, 01:27:44 PM »
Thanks!
Wim
BAM!
That was it. https://www.txweather.org/wxrecordsalltime.php Now I have some data. I still have to fix what is shwoing wrong. Not sure what is causing that one.
Precipitation Records
Highest Daily Precipitation    0.00 in    12/31/2015
Highest Monthly Precipitation    in    /
Highest Precipitation Rate    0 in/hr    12/31/1969
Consecutive Days With Precipitation    0 Days    Ending: 12/31/2015
Consecutive Days Without Precipitation    Days    Ending: 12/31/1969
I think is because my 2015 import is not done.
Man this is awesome!
Thanks so much Wim!
    • Texas Weather
« Reply #7 on: July 01, 2019, 08:59:34 PM »
ok my precipitations is screwed up. I cant make it show up correctly. Any ideas why?
