Author Topic: PWS_Dashboard, another HWS-template for . . .  (Read 1135 times)
Offline wvdkuil
  • Wim van der kuil
« on: June 20, 2019, 09:24:59 AM »
Current release: December 2019 = Long-Time-Support version
Available for the following weather-upload files and weather-programs:
WDapi as used by WeatherDisplay
clientraw.txt  as used by WeatherDisplayMeteohub , WSWIN and others
realtime.txt as originally defined and still used by Cumulus
and which can also be used by Weewx, WeatherCat, WiFiLogger, WeatherLink, Meteobridge and others
The PWS_Dasboard can also be used without a weather-program when you are uploading to
Weatherlink.com , WeatherUnderground , AmbientWeather net or WeatherFlow
Tested and used with 11 different weather-programs and 4 Weather-Nets.
Latest addition in the December release is:
AmbientWeather.net => https://pwsdashboard.net/pwsWD/   in the default mode with 4 rows of 3 blocks, rounded items
WARNING: Although there are similarities in look&feel, this template is very different from other HWS-templates such as the  the w e a t h e r 3 4/ template.
Do not mix/match different templates and always ask for support at the right place / person
Wim
« Last Edit: December 21, 2019, 04:38:49 AM by wvdkuil »
Offline wvdkuil
  • Wim van der kuil
Re: PWS_Dashboard, another HWS-template for . . .
« Reply #1 on: December 21, 2019, 04:27:23 AM »
The 2019-December release is introduced and now also supports AmbientWeather.net, check demo here
I adapted the first post to reflect all changes / links
Wim
« Last Edit: December 21, 2019, 04:40:06 AM by wvdkuil »
