Author Topic: Driver for USB logger?  (Read 670 times)
Offline Tazz 316
« on: May 27, 2019, 04:20:16 PM »
Is installing davis weather link still needed? or is there a standalone driver. If i remember you had to install there software before the logger would work.
Offline waiukuweather
Re: Driver for USB logger?
« Reply #1 on: May 27, 2019, 05:00:15 PM »
google silicon labs davis usb driver
Online mcrossley
    • Wilmslow Astro
« Reply #2 on: May 27, 2019, 06:04:02 PM »
And the logger needs to be switched to "serial port mode" - forget the correct term for it off the top of my head. I think that was the only requirement for using the Davis software.
The third-party USB loggers already work in serial port mode.
Offline Tazz 316
« Reply #3 on: May 27, 2019, 06:06:43 PM »
Got it to work on the first try!
Offline WxFox
  • Northern Androscoggin Weather
  • Happiness is having my toes in the warm sand.
    • Northern Androscoggin County Weather
« Reply #4 on: May 27, 2019, 06:36:18 PM »
I would install it anyway. It's an easy way to set alarms and do other things. I use it only for that.
Davis VP2 (cabled) Uploading to PWS, Weather Underground, Weathercloud, WOW, WeatherBug, AWEKAS and Twitter, using Cumulus.  Cabled = fewer problems, less maintenance and better reliability!
Northern Androscoggin Weather:
http://home.myfairpoint.net/~jody2011/index.php
Mobile friendly: http://home.myfairpoint.net/~jody2011//iCumulus/#_home
CWOP AV346
