Author Topic: River/Lake Height script issue  (Read 409 times)
Offline sacreyweather
  • Echo Valley Weather
« on: May 25, 2019, 10:49:40 AM »
Hi Folks,
Ran into an issue with my River/Lake Height script. I "think" it's an XML formatting problem, but not sure.
You can see the issue here. This also happens on the pages for the Ozark, Pine Bluff and Pendelton detail pages as well.
Here is the link to the Van Buren XML page:
Thanks in advance for the assistance,
« Last Edit: May 25, 2019, 10:55:34 AM by sacreyweather »
CWOP: D2073, GR2AE, GR3, Cumulus, PWSweather,  CoCoRaHS: AR-SL-23
Saline Weather on Twitter
Offline the beteljuice
  • the beteljuice
    • test site
Re: River/Lake Height script issue
« Reply #1 on: May 25, 2019, 01:49:22 PM »
Can't see anything ..... get 403 - Forbidden
« Reply #2 on: May 26, 2019, 09:27:08 AM »
Hi Beteljuice,
My apologies, I did not realize I had the United Kingdom blocked. You should be able to see it now.
  • the beteljuice
    • test site
« Reply #3 on: May 26, 2019, 05:38:42 PM »
Wooly Web Wisdom says ...
main(): Node no longer exists in /home/sacrey/www/www/wxriverdetail.php on line 76
Warning: main(): Node no longer exists in /home/sacrey/www/www/wxriverdetail.php on line 89
Means that the array or attribute you are tying to use is empty or doesn't exist.
« Reply #4 on: May 26, 2019, 06:21:07 PM »
Thanks, Beteljuice. I will learn on how to correct this.
