Author Topic: Weather Underground Website Main Menu - PM2.5 Data  (Read 5087 times)
« on: May 22, 2019, 04:55:49 PM »
The Weather Underground Main Menu has 29 links in drop downs. Of those links 6 of them do not work. That is almost 21% of the menu links not working.
I'm trying to find where PM2.5 data shows up from the following station that just started reporting PM2.5 to WU.
https://www.wunderground.com/dashboard/pws/KFLWINTE862
These are probably two separate issues ...but I'm not sure. I read that you can find PM2.5 in the U.S. Counties Health Map & Air Pollution Monitors, but I don't know where that is.
« Last Edit: May 22, 2019, 05:20:50 PM by galfert »
Re: Weather Underground Website Main Menu - PM2.5 Data
« Reply #1 on: May 22, 2019, 05:08:25 PM »
I found it:
https://www.wunderground.com/health/us/fl/winter-springs/KFLWINTE862?cm_ven=localwx_modaq
Not showing up yet though in the "NEARBY POLLUTION MONITORS". Maybe it takes a day.
« Last Edit: May 22, 2019, 05:21:05 PM by galfert »
« Reply #2 on: May 22, 2019, 05:17:00 PM »
If anyone wants to know how to get to that for your location, start with any WU station dashboard.
Then click on the city name under the Station Name.
Then click on Air Quality and you are there.
* Your station does not need to have an air quality sensor to see this. These steps will take you to show you the nearby air quality sensors around you.
« Last Edit: May 22, 2019, 05:21:17 PM by galfert »
Offline quailvalleywx
« Reply #3 on: May 26, 2019, 12:15:09 PM »
Thanks for the info.  From WU's data ingest protocol, https://feedback.weather.com/customer/en/portal/articles/2924682-pws-upload-protocol?b_id=17298 I saw they accept PM2.5 and PM10 data via AqPM2.5 and AqPM10.  I started sending that data a couple days ago but I don't see it listed in my city's list of nearby sensors. It looks like they just import Purple Air data at the moment. When I get a chance I'm going to add AQI data to the overlay on my webcam image - and with luck maybe WU displays webcam images, or not ;)
There are other posts on wxforum about making your own Purple Air. This is what I did which uses the same internal sensor and an ESP8266-12f to send data via WiFi https://github.com/mrcodegh/PMS7003.
Mike.
WS-1400-IP, Galaxy S3 for cloud cam and Web Server
QV Website | Source Code | WU | WC | PWS | MesoWest/CWOP
« Reply #4 on: May 26, 2019, 12:39:54 PM »
Yes it seems WU is accepting my PM2.5 data but I'm not seeing it show up either in nearby sensors. It does seem like you said that for now all they are doing is receiving data from Purple Air's website.
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • An old Alaska guy living in an insane world.
« Reply #5 on: May 31, 2019, 01:07:16 AM »
I have a PM2.5 sensor and am reporting to Ambient Weather. It is only for particulate matter. It does show on my station page
here: https://dashboard.ambientweather.net/dashboard
The air quality shown on WU is from the local AQMD and not my station. It uses more parameters in its calculation.
Here: https://www.wunderground.com/weather/us/ca/grass-valley/KCAGRASS150
« Last Edit: May 31, 2019, 01:10:09 AM by Weatheroger »
Ambient Weather WS-2902, IP Observer v4.6.2
Ecowitt GW1000B- WIFI17FC v1.7.8, GW1200B v1.3.8, GW3000B v1.0.6
Sending weather data to, Ambient CWOP, Ambient Weather, AWEKAS, Ecowitt, PWS Weather, Weathercloud, Wunderground, MADIS, and APRS Using Cumulus MX dashboard.
Ambient Weather  https://ambientweather.net/dashboard/b71db9ae6b3ebd3a3db1864a6b9eeb2b
Ecowitt Station https://www.ecowitt.net/home/share?authorize=SEJRPK
AEKAS https://stationsweb.awekas.at/home?id=20470
CumulusMX v4.5.0 build 4103
« Reply #6 on: September 25, 2019, 10:17:05 AM »
I noticed that Wundermap recently? has air quality PM2.5 and PM10 data from Purple Air but PM2.5 and PM10 data sent to http://rtupdate.wunderground.com are still ignored.  Hopefully WU will start to propagate ingested air quality data but based on lack of progress on other items we still have a long wait.
Offline watsonm
« Reply #7 on: December 13, 2022, 06:01:45 AM »
An update after three years !!!
I have been sending AqPM2.5 and AqPM10 readings to  weather underground along with all my other readings and they STILL don't show.   I suspect they
are getting the data  from the purple air site   so that they are "validated".  You need a valid purple air device  MAC  to send data there!
(I use a single PMS5003 unit which cost me about 30$ so how they justify nearly 300$ for their dual unit I am not sure.)
Regards Mike
Raspberry Pi 4
Directly connected : BMP388 pressure sensor.  DHT22 For internal Humidity Sensor temp
Wireless connected: 3 Temperature Transmitters(WS2083), WH57  Lightning Sensor, Fine Offset Solar sensor  (stand alone)
Offline Zorglubxx
« Reply #8 on: March 05, 2023, 09:00:07 AM »
My weather station uploads directly to WU and I've tried to upload separately the AqPM2.5 and AqPM10 readings from my PM2.5 sensor but when I do, my WU data for temperature, pressure, wind etc goes blank until it gets another measurement from the weather station. So not only WU won't display these PM2.5 readings, but I would have to find a way to upload all the data together in one go.
Any suggestions for a good site to use to upload this sensor data (international)?
