Author Topic: ios and Android apps reporting garbage (again)  (Read 394 times)
Offline farcus
« on: May 12, 2019, 06:19:39 AM »
This issue first appeared about a month or so ago (just after the first updates) but then appeared to get fixed.
However, today the issues have resurface on both ios and android apps.
You'll see in my screenshots below.
click the map in the app and choose my station from the app . . .
everything in this screen is ok
if I then click "view forecast" the location is correct but the data is coming from some unknown weather station named "Oamaru airport"
interestingly, there is no "station info" button for this station.
Clicking the station shows my location on the map but with an airport icon over it.
This corrected itself previously. Others have reported installing an earlier version of the WU app fixed it for them. I tried this (5.8.x) but got exactly the same incorrect results.
Checked on another android phone with a fresh install of the app and got exactly the same incorrect results.
Checked on ios and got the same wrong data again - so it is certainly garbage data coming out of WU.
Offline farcus
Re: ios and Android apps reporting garbage (again)
« Reply #1 on: May 12, 2019, 06:25:26 AM »
Also, there is another station within a few hundred metres of mine.
This also displays an incorrect name - but for this station the "station info" button is present.
If I click that I get this screen . . .
Offline cmg
« Reply #2 on: May 13, 2019, 05:30:30 PM »
Hi
I do not know if it's related but ...
I use Weather Station app on my Android to see the data from my personal station but, since 9 days ago, no more data is uploaded. Nor from my station or from any other.
Any help is welcome.
Regards
Offline Weatheroger
« Reply #3 on: May 13, 2019, 07:27:56 PM »
Showing current on my Android phone ver: 7.7.7.1
Offline farcus
« Reply #4 on: May 13, 2019, 08:00:32 PM »
Hi
Regards
I don't think it is related as my station is reporting fine and appears correct using the web interface - just in android and ios apps reporting station is incorrect.
Offline farcus
« Reply #5 on: May 15, 2019, 08:43:23 PM »
hmmmm . . .  seems to be fixed now.
Had to clear the cache from the app and load again but all looking good (for now)
