Author Topic: MySQL help, shrink database by combining multiple rows into max/min/average  (Read 1397 times)
Offline lightmaster
  • MB-HWS Template Dev
    • Baxley,GA Weather
I have a database that has my weather written to it every 10 seconds. After around 10 months, I now have a little over 1.4 million records, so I'd like to try to compress that a bit to improve performance and reduce the size over long term. I'd like to shrink the data that's older than 1 month by combining the data into 5 min intervals, using things like the max temp in the 5 min window, average wind direction, etc. So in a 10 min period, instead of having 60 records with 10 seconds between them, I'd have 2 records with 5 minutes between them.
I've used queries like this to see data based on a time range, but not sure how to do a query that loops based on the timestamp and creates another table with that new data.
SELECT MIN(TempInCur), MAX(TempInCur), MIN(HumInCur), max(HumInCur), min(PressCur), max(PressCur), min(TempOutCur), max(TempOutCur), min(HumOutCur), max(HumOutCur), min(DewCur), max(DewCur), min(HeatIdxCur), max(HeatIdxCur), max(WindSpeedCur), max(WindGust10), max(WindAvgSpeedCur), min(WindChillCur), max(WindChillCur), MAX(RainYear), MAX(RainRateCur), max(UVIndex), MAX(Evapotranspiration), MAX(Radiation) FROM `KGABAXLE9` WHERE `DateTime` >= '2019-01-01' ORDER BY `DateTime` DESC LIMIT 1
If it helps, here's the format of my table:
CREATE TABLE `KGABAXLE9` (
 `ID` int(11) NOT NULL AUTO_INCREMENT,
 `DateTime` datetime NOT NULL COMMENT 'Date and Time of Readings',
 `TempOutCur` decimal(4,1) NOT NULL COMMENT 'Current Outdoor Temperature',
 `HumOutCur` int(11) NOT NULL COMMENT 'Current Outdoor Humidity',
 `PressCur` decimal(4,2) NOT NULL COMMENT 'Current Barometric Pressure',
 `DewCur` decimal(4,1) NOT NULL COMMENT 'Current Dew Point',
 `HeatIdxCur` decimal(4,1) NOT NULL COMMENT 'Current Heat Index',
 `WindChillCur` decimal(4,1) NOT NULL COMMENT 'Current Wind Chill',
 `TempInCur` decimal(4,1) NOT NULL COMMENT 'Current Indoor Temperature',
 `HumInCur` int(11) NOT NULL COMMENT 'Current Indoor Humidity',
 `WindSpeedCur` decimal(4,1) NOT NULL COMMENT 'Current Wind Speed',
 `WindAvgSpeedCur` decimal(4,1) NOT NULL COMMENT 'Current Average Wind Speed',
 `WindDirCur` int(11) NOT NULL COMMENT 'Current Wind Direction (Degrees)',
 `WindDirCurEng` varchar(3) NOT NULL COMMENT 'Current Wind Direction (English)',
 `WindGust10` decimal(4,1) NOT NULL COMMENT 'Max Wind Gust for Past 10 Mins',
 `WindDirAvg10` int(11) NOT NULL COMMENT 'Average Wind Direction (Degrees) for Past 10 Mins',
 `WindDirAvg10Eng` varchar(3) NOT NULL COMMENT 'Average Wind Direction (English) for Past 10 Mins',
 `RainRateCur` decimal(5,2) NOT NULL COMMENT 'Current Rain Rate',
 `RainDay` decimal(4,2) NOT NULL COMMENT 'Total Rain for Today',
 `RainYest` decimal(4,2) NOT NULL COMMENT 'Total Rain for Yesterday',
 `RainMonth` decimal(5,2) NOT NULL COMMENT 'Total Rain this Month',
 `RainYear` decimal(5,2) NOT NULL COMMENT 'Total Rain this Year',
 `Radiation` decimal(6,2) NOT NULL COMMENT 'Current amount of Solar Radiation (W/m^2)',
 `Evapotranspiration` decimal(5,2) NOT NULL COMMENT 'Solar Evapotranspiration',
 `UVIndex` decimal(3,1) NOT NULL COMMENT 'Current UV Index (uvi)',
 `ForecastRule` int(11) NOT NULL COMMENT 'Forecast number from Davis',
 PRIMARY KEY (`ID`),
 KEY `TempInCur` (`TempInCur`),
 KEY `TempOutCur` (`TempOutCur`),
 KEY `HumOutCur` (`HumOutCur`,`PressCur`,`DewCur`,`HeatIdxCur`,`WindChillCur`,`HumInCur`,`WindSpeedCur`,`WindGust10`,`RainDay`,`RainYest`,`RainMonth`,`RainYear`),
 KEY `DateTime` (`DateTime`)
) ENGINE=InnoDB AUTO_INCREMENT=1410532 DEFAULT CHARSET=utf8
Offline davidg_nz
    • Sandy Bay Weather
I don't know how well MySQL implements SQL92 date/time stuff but this is pretty easy to do in PostgreSQL. I use a query similar to below in my own software for computing 30 minute averages where the time-stamp is the time at the start of the 30 minute period (the javascript chart library I used was struggling with a month of data at 5 minute resolution).
with weather_data as (
    select
        (extract(epoch from "DateTime"::date) + extract(hour from "DateTime")::int) * 10 + extract(minute from "DateTime")::int / 5 as period
    from "KGABAXLE9"
SELECT
    min("DateTime"),
MIN("TempInCur"),
MAX("TempInCur"),
    MIN("HumInCur"),
    max("HumInCur"),
    min("PressCur"),
    max("PressCur"),
    min("TempOutCur"),
    max("TempOutCur"),
    min("HumOutCur"),
    max("HumOutCur"),
    min("DewCur"),
    max("DewCur"),
    min("HeatIdxCur"),
    max("HeatIdxCur"),
    max("WindSpeedCur"),
    max("WindGust10"),
    max("WindAvgSpeedCur"),
    min("WindChillCur"),
    max("WindChillCur"),
    MAX("RainYear"),
    MAX("RainRateCur"),
    max("UVIndex"),
    MAX("Evapotranspiration"),
    MAX("Radiation")
FROM weather_data
group by period
order by period desc
Note that the :: syntax above ("DateTime"::date) is a Postgres-specific cast shortcut - the correct way in most other database engines would be cast("DateTime" as date).
Port Charles, Coromandel, New Zealand | Wired Vantage Pro2+, Ubiquiti AirCam
Hamilton, Waikato, New Zealand | Wireless Vantage Pro2+, 24h FARS, Leaf+Soil Station, Envoy
