Author Topic: Wu PWS and Account Migration Status Updates  (Read 5624 times)
Offline PraveenC31
Re: Wu PWS and Account Migration Status Updates
« Reply #75 on: April 14, 2019, 06:23:54 AM »
 Not able to change to metric on mobile yet
Offline Chula
« Reply #76 on: April 14, 2019, 08:32:48 PM »
Webcam has been down for several weeks now. Tried deleting and re-adding and tried to add a second camera with no luck.
Via FTP
Station ID: KMITROY6
Webcam Name: ChulaCAM1
Offline Weatheroger
« Reply #77 on: April 14, 2019, 09:51:32 PM »
Via FTP
Per previous posts in this thread WU is aware and working on a fix. Please be patient.
Offline tractor
« Reply #78 on: April 15, 2019, 12:52:28 PM »
My webcam is back up which is great, even if the square formatting is a bit weird.
But what has not worked at all since the change is UV. It shows unavailable. Cumulus is showing UV of 1.1 so I know it's receiving the data.
Anyone else seen their UV come back up yet?
Offline antstrafer
« Reply #79 on: April 15, 2019, 01:00:07 PM »
uv good on chrome here
Davis Vantage Pro2 plus     Meteobridge
CWOP FW5142    PWS THAI817    MADIS F5142
WU KTXTHALI2    AWEKAS           weatherobs
Offline crawdad62
« Reply #80 on: April 15, 2019, 01:15:49 PM »
UV and Solar have worked well anytime the rest of the data stays in sync.
Offline Jim_S
« Reply #81 on: April 15, 2019, 01:31:49 PM »
What's you station ID on WU? What type of station do you have? It's hard to provide good feedback without knowing that.
Offline tractor
« Reply #82 on: April 15, 2019, 05:18:12 PM »
Thanks folks.
It's a Davis Vantage Pro2 (Wireless) with Davis UV and Solar sensors.
« Last Edit: April 16, 2019, 11:40:31 AM by tractor »
Offline PaulMy
« Reply #83 on: April 15, 2019, 06:02:36 PM »
My UV is showing:
Cumulus 1 Davis USB logger  http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IONTARIO226
Cumulus MX/WiFiLogger   http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IMIDDLES37
Enjoy,
Offline davidmc36
  • Morewood Ontario Canada
    • IONOTTAW14
« Reply #84 on: April 15, 2019, 09:30:05 PM »
My webcam is back........
I show Offline for the first time vs Not Associated. I assume mages will still be intermittent with only one of three FTP working as I last saw reported.
https://www.wunderground.com/dashboard/pws/IONOTTAW14
« Reply #85 on: April 16, 2019, 05:38:04 AM »
It looks to me like your UV was not reporting to WU since before the migration to the new WU site. I know it doesn't seem that way to you so hear me out. Start by looking at the old WU site and go back in time to before the WU new site (March 18). Go way back in time too. Check many dates.
http://horizon.wunderground.com/personal-weather-station/dashboard?ID=KUTNORTH14
What you'll notice on the old site for your station is that there is solar radiation but there is no data nor graphs for UV. So you are asking yourself why did you see UV on the old site for live data. The reason is because on the old WU for any site that did not report UV then WU would use external sources to show a live UV for your station. But only live UV and no UV history. There are other people claiming that their UV went away with the new WU. Some people just now realize that their station doesn't have UV. But you are saying to yourself that you do have UV and you can see it in Cumulus. Well the problem seems like Cumulus in your case is not set right to send UV to WU....it never has sent UV to WU as evidenced by looking at your old WU site.
But Cumulus is capable of sending UV. Just take a look at PaulMy's old WU also running Cumulus 1 and you'll see how he does have both UV and Solar in both graphs and data.
http://horizon.wunderground.com/personal-weather-station/dashboard?ID=IONTARIO226
So something is up with your Cumulus as it never has sent UV to WU.
« Last Edit: April 16, 2019, 05:51:05 AM by galfert »
Offline Weatheroger
« Reply #86 on: April 16, 2019, 11:32:39 AM »
UV showing on both old and new pages. Both read the same.
Offline tractor
« Reply #87 on: April 16, 2019, 11:40:17 AM »
Thank you galfert. I thought all of those options were checked, but clearly it wasn't! Should be reporting now.
Offline Eno
« Reply #88 on: April 16, 2019, 01:20:34 PM »
I wonder if WU could make the map area have a tab to switch between the map and webcam (if present), like the previous layout had.  The best part of the old layout was seeing my webcam image prominent alongside the data.  Having those two elements together really added to a whole greater than the sum of the parts. Now, having to scroll to the bottom for the webcam image is kind of a drag.
I understand that PWS's having an associated webcam is the exception rather than the rule, (I wonder what %, guessing 10-15%) but maybe if webcam images were more prominently positioned it would motivate additional PWS owners to add a webcam.  KIDBOISE93
Offline CR1400IP
« Reply #89 on: May 02, 2019, 12:38:56 PM »
When will be the decimals be back. Awaiting eagerly
Page much more responsive than before.
Few more tweaks welcomed as map and webcam switch in same frame.
Offline DixonAgee
« Reply #90 on: May 19, 2019, 05:31:11 PM »
I was waiting for other items to be fixed before bringing this up.  My station KNVGARDN124 is named "Springfield Drive". It shows correctly if I log in to my account and bring up My Devices.  HOWEVER, it shows up incorrectly on the PWS map an and other situations as "GARDNERVILLE" or "GARDNERVILLE STATION".  Can you fix this?  Thanks.
Offline Weatheroger
« Reply #91 on: May 19, 2019, 07:00:37 PM »
WU is aware of this and working on a fix.
