Author Topic: Support of the "Leuven" Forecast scripts  (Read 17778 times)
Offline wvdkuil
  • Wim van der kuil
Re: Support of the "Leuven" Forecast scripts
« Reply #150 on: March 01, 2024, 02:26:49 AM »
Could you please tell me if there is any fix that I can apply to stop these errors occurring
Hi Keith,
Thanks for the zip.
There are very strange errors, I have to investigate today how and what is causing this.
and hence have no errors reported when the Norway forecast is accessed my website?
Script: _metric_settings.php
Lines 8-12 now read:
#                       error messages on or off
#    always set to false for production versions
$ws_errors      = true; # false when ready testing
Change in line 12 the word true  to false
This will not solve the real problem.
But there should be no error messages.
I will do some testing to see if the problem occurs here also.
Regards,
Wim
« Last Edit: March 01, 2024, 02:29:03 AM by wvdkuil »
Offline wvdkuil
  • Wim van der kuil
« Reply #151 on: March 01, 2024, 05:42:42 AM »
Hi Keith,
Thanks for the zip.
Hi Keith,
I captured the metno-data for your location to test with.
Attached a version which add another  check for  "incomplete" day-parts.
Make a copy of your current wsIncMetnoHtml4.php script before replacing it.
It should remove most errors form your error log, but I could not produce all messages you had.
Regards,
Wim
« Last Edit: March 01, 2024, 05:50:39 AM by wvdkuil »
Offline griffo42
    • Carina Weather
« Reply #152 on: March 01, 2024, 06:26:26 AM »
Thanks for your prompt replies and help in this matter.  I have done what you asked in replies 150 & 151.  We will see what happens in the next few days.
Keith
https://www.kstwx.net/index.php
Davis Vantage Pro2 Model #6152AU
Cumulus latest version
Saratoga Weather World template Cumulus plugin
Carina Weather, Brisbane.
Offline griffo42
    • Carina Weather
« Reply #153 on: March 07, 2024, 04:50:46 PM »
Hi Wim
This appeared when checking my website this morning:
Also since updating the wsIncMetnoHtml4.php script as requested, the times of "forecast data created at" and "next update" at page top right as well as the "forecast data created at &c" at bottom right do not appear.
Thanks for your continued help.
Keith
Offline wvdkuil
  • Wim van der kuil
« Reply #154 on: March 08, 2024, 03:15:43 AM »
Hi Wim
There are two causes for this warning:
1. Maintenance at met.no
-> Please click the link, the link will run in your browser and it will contain a message from met.no why there was no data.
2. A problem with accessing the met.no website from your web-server.
-> Right click at the message and select "show html" or similar (depends on your borwser).
This will show the complete html.
As we switched off the test-mode, the date/times are not shown according to the settings.
From API version 2 they are not always "correct"
But you can switch them on in your page-settings in wsMetnoPage.php. Lines 62 - 67 now read
#                         some yes / no settings
#   true = display loading time of this forecast
#               false = do not display time info
$metno_times            = false;
Change that false on line 67 to true
Succes,
Wim
Offline griffo42
    • Carina Weather
« Reply #155 on: March 09, 2024, 02:15:16 AM »
Wim
Thank you.
Keith
