Author Topic: Support of "Leuven" Air Quality scripts  (Read 3687 times)
Online wvdkuil
  • Wim van der kuil
« on: March 28, 2019, 12:10:11 PM »
I coded the Purpleair (PA-II)  and the Luftdaten scripts in a similar way. Probably most questions/problems are similar, so both scripts will be supported in this topic.
PurpleAir  NEW VERSION as of 2019-11-22
Demo: https://weather-template.nl/purpleair/index.html
Download: https://leuven-template.eu/leuven_download2019.php?id=purpleair
Readme: You will find the read-me pdf in the download, but you can read it here in a new window also.
Known issues:
For extended version2: upload to own website fails nearly always
==> added a fall-back in sensor script by downloading from the purpleair website
Luftdaten
Demo: https://leuven-template.eu/luftdaten/index.html
Download: https://leuven-template.eu/leuven_download2019.php?id=luftdaten
Known issues: link will be added when needed
There are two versions of these scripts which both can be accessed and studied from the demo-page.   The "basic version" reads your data form the suppliers database.  A more "extensive version" expects the sensor to upload the row measurements to your own web-server.  This will need more knowledge about http-bypass in your webserver-htaccess file.
Support:
When you post questions about the scripts, please always include the URL (=correct link)  to the script on your website. That reduces the time for answering your questions.
« Last Edit: November 22, 2019, 06:53:56 AM by wvdkuil »
Support for Leuven-Template & Scripts  at this forum via https://support.leuven-template.eu/
Script sponsors support.leuven-template.eu/userlistScripts.php
Template sponsors support.leuven-template.eu/userlist.php
Re: Support of "Leuven" Air Quality scripts
« Reply #1 on: March 28, 2019, 01:50:59 PM »
Thanks, Wim!
Offline txweather.org
    • Texas Weather
« Reply #2 on: March 28, 2019, 03:17:02 PM »
Thanks again! YAY! :D
Offline Stegrie
    • Wetterstation Johanngeorgenstadt
« Reply #3 on: November 18, 2019, 11:55:10 AM »
Hi wim
The test1 is working perfect test2 has an Error
https://www.wetterstation-johanngeorgenstadt.de/purpleair/_test2.php
https://www.wetterstation-johanngeorgenstadt.de/purpleair/_test1.php
with your Sensor ID work test2 with mine not why
Stefan
Online wvdkuil
  • Wim van der kuil
« Reply #4 on: November 18, 2019, 12:31:22 PM »
Hi wim
Stefan
The test2 works when you upload the data from your purpleair sensor. You have to instruct the sensor to do that.
More info; https://www.wetterstation-johanngeorgenstadt.de/purpleair/_readme%20FIRST.pdf => 4. Upload our data
There were / are/ often problems when  the data/ folder to upload into is on an https server
Succes, Wim
Offline Stegrie
« Reply #5 on: November 21, 2019, 05:17:21 AM »
Hi Wim,
Have do this new and also again, test2 not work
4. Upload our data -> Step by Step
https://www.wetterstation-johanngeorgenstadt.de/sensorpurple2.php -> ok
https://www.wetterstation-johanngeorgenstadt.de/purpleair/_test2.php -> Error, not found the File
it's a Cache thing? I have all do as described,nothing else changed.
Stefan
« Last Edit: November 21, 2019, 05:19:41 AM by Stegrie »
Online wvdkuil
  • Wim van der kuil
« Reply #6 on: November 21, 2019, 05:52:24 AM »
Hi Wim,
Stefan
I have no idea.
But
1. you should create a data/ folder on your server
2. set line 12 in sensorpurple2.php to comment
$save_last_mes  = true;
#$save_last_mes  = false;
3. check if there is anything arriving in the data folder.
The purpleair sensor sends the data to
=> sensorpurple2.php
==> that script
===> stores the received measurements in an array in the data/ folder
 and
===> optionally writes the received data into a text file to inspect:   data/last_purple_data_ 14151.json
Also important, did you add https://  before the www in the link in your purpleair sensor?
Success,
Offline Stegrie
« Reply #7 on: November 21, 2019, 06:15:32 AM »
Hi
Thanks have set the new Data Folder now in these Folder: see Attachment
Test2 not work have these also to the Attachment
last_purple_data_14151.json, Ds Store, and purple_24data_14151.arr cannot attach, but there is in the new data Folder
$save_last_mes  = true; -> have set
#$save_last_mes  = false; -> have set
test2 will not work
Stefan
Offline Stegrie
« Reply #8 on: November 21, 2019, 06:28:05 AM »
Hi in the json stands :false
array is in attach
Online wvdkuil
  • Wim van der kuil
« Reply #9 on: November 21, 2019, 06:28:22 AM »
Hi
test2 will not work
Stefan
https://www.wetterstation-johanngeorgenstadt.de/data/last_purple_data_14151.json
==> is there but it has got no or no good data last time is was accessed
===> check if the date /time of that file changes according  to the uploads from purpleair
https://www.wetterstation-johanngeorgenstadt.de/data/purple_24data_14151.arr
==> is there and seems  a correct PHP-array
===> but it can not be accessed by the script https://www.wetterstation-johanngeorgenstadt.de/purpleair/_test2.php
====> so probably the permissions are not correct.
Could you please set the permissions for the data/ folder and alll its contents to #0777 or read/write by world?
Offline Stegrie
« Reply #10 on: November 21, 2019, 06:35:41 AM »
set to 0777 no luck
see:https://www.purpleair.com/data.json?show=14151&key=XRBTRTSYC512PMRC
yes it changed Date+ Time when run sensorpurple2.php
« Last Edit: November 21, 2019, 06:43:27 AM by Stegrie »
Online wvdkuil
  • Wim van der kuil
« Reply #11 on: November 21, 2019, 06:53:56 AM »
set to 0777 no luck
https://www.wetterstation-johanngeorgenstadt.de/data/  gives a 403 error, so the permissions are (to) low.
https://www.wetterstation-johanngeorgenstadt.de/data/last_purple_data_14151.json  always contains false, so the data is not (correct) sent by the sensor or other error
Question: did you set https://  or http:// before www.wetterstation. . .   in the purpleair sensor
TODO:
You did put the scripts in purpleair/ws_purpleair2.php  in their own folder.
You then have to change  line 7 in ws_purpleair2.php   from
$useOwnDir      = './data/';  to
$useOwnDir      = '../data/';  There should be TWO points to tell the script the data folder is 1 level below its own folder.
« Last Edit: November 21, 2019, 06:55:29 AM by wvdkuil »
Online wvdkuil
  • Wim van der kuil
« Reply #14 on: November 21, 2019, 08:45:15 AM »
hi Wim
it works but all Data is 0 in there json
https://www.wetterstation-johanngeorgenstadt.de/purpleair/ws_purpleair2.php
The receiving script sets the value 'false"  so that means no data or no correct data received on your webserver..
Some setting in the purpleair is wrong
or
some communication problem between purpleair and the receiving script.
There were often problems when using https:// servers in the past also.
I have to think how we can test that.
Online wvdkuil
  • Wim van der kuil
« Reply #15 on: November 21, 2019, 09:10:31 AM »
hi Wim
or
Why is there user:password in the settings in purpleair  header?
Offline Stegrie
« Reply #16 on: November 21, 2019, 09:16:48 AM »
as in the Instruction say:
At the Key 3 field you enter the exact URL http://www.website.com/sensorpurple2.php
Key4 you type user:password
and Method you leave “Post” as it is
Data Provider #2: Custom
Data Provider #2 URL: http://www.website.com/sensorpurple2.php Data Provider
#2 HEADERS: user:password
Data Provider #2 METHOD: POST
Offline Stegrie
« Reply #17 on: November 21, 2019, 09:19:51 AM »
you need the Link to change these settings  per PM?
or give the email to forwarding the Mail from purple air to you
find in pm to you
« Last Edit: November 21, 2019, 09:25:21 AM by Stegrie »
Offline Stegrie
« Reply #18 on: November 21, 2019, 09:47:52 AM »
message (mail) sent to you from here
Online wvdkuil
  • Wim van der kuil
« Reply #19 on: November 21, 2019, 10:56:32 AM »
find in pm to you
I have my own Purpleair sensor but it failed uploading to my own server in June, no big problem as I always used the type-1 output on my site. Uploading was only needed when there was a user-problem as you have.
My current purpelair, which is a few years old, shows at the bottom of the sensor page
NTPLOCUPDPAATSATSS3RDTSBTSS3RD
V4.11 2.0+OPENLOG+15833 MB+DS3231+BME280+PMSX003-B+PMSX003-A
I tried all settings possible on the registration page.
With my version it is impossible to sent information to an https or an http site using post, get or put.
The messages arrive, but there is no data in the message, as it was until June this year.
Using $_REQUEST, GET , POST  or 'php://input' returns no data at all.
Maybe your sensor has the same problem,
« Last Edit: November 21, 2019, 11:12:19 AM by wvdkuil »
Online wvdkuil
  • Wim van der kuil
« Reply #20 on: November 22, 2019, 06:55:57 AM »
First message is adapted for a new version of the PurpleAir script.
The upload to ones own website seems to fail at 99% of the user-sites
I added a "fall-back" so, when there is no sensor data arriving directly, the sensor script reads the latest sensor-data from the PurpleAir database.
« Last Edit: November 22, 2019, 07:10:21 AM by wvdkuil »
Offline Stegrie
« Reply #21 on: November 22, 2019, 10:16:55 AM »
Now works with Version 2 many thanks Wim
Offline marko30
« Reply #22 on: January 26, 2020, 03:15:25 PM »
For me _test2 is working ok, but saratoga page not.
https://okroglovreme.com/wxAqLuft.php
https://okroglovreme.com/luftdaten/ws_luftdaten2.php
what is correct record in setting?
$userSensor     = 'esp8266-XXXXXX'
or
$userSensor     = 'XXXXXX'
any toughts?
thx.
« Last Edit: January 26, 2020, 03:21:35 PM by marko30 »
Online wvdkuil
  • Wim van der kuil
« Reply #23 on: January 27, 2020, 01:17:33 PM »
or
any toughts?
thx.
I am on vacation with insufficient internet. The sensor in your case is the displayed in the test2 page, I think 38115
I will check it when I am back Feb 1/2 depending on some strikes.
Edited Febr 1: Seems working correctly now.  Wim
« Last Edit: February 01, 2020, 12:06:41 PM by wvdkuil »
Offline plex
« Reply #24 on: February 23, 2020, 05:40:44 AM »
Thanks for yet a great script from Leuven [tup] =D>
I've got everything working, except the "Luftdaten map" inside the "my_AqhiLuft2Page.php". I've found other Leuven templates, where it's actually working, so I suspect I didn't do everything correct #-o Anyways there are only 4 Luftdaten users visible on the map in Denmark.
Could it be a path related problem? I've copied the files to weather28/_my_scripts dir, and kept the data dir in weather28/luftdaten/data. The graphs didn't work before changing the path to:
# ----------  we load our own sensor to our site
$useOwnDir      = './luftdaten/data/';
As I understand from the readme file, I shouldn't be necessary, to change path if I use weather28/ for the template?
https://www.vejrstationen.dk/weather28/index.php?p=mnu_aqhi_luft&wp=MB&lang=en
