Author Topic: My new Atlas install  (Read 686 times)
Offline karlzemlin
    • The weather at my house
« on: February 03, 2019, 11:14:02 AM »
I had a 5-in-1 since January of '16 that worked well for me.  It was on a PVC pole mounted at the peak of my garage.  I used heavy monofilament fishing line for guy lines since the PVC was so whippy.
This winter one of the guy lines broke and before I had a chance to repair it a cold, windy day broke the pole.  The sensor was destroyed.
I was going to just buy a new 5-in-1 sensor, but when I saw the Atlas had the option to remote the windy bits I decided to upgrade.  I took the opportunity to make a major upgrade on my mount arrangement too.  I'm a mechanical engineer and I have a 3D printer.  I used the printer to make some parts to add support and adjustment to my cantilevered mount to the house.  I used 1-1/2" and 1" aluminum tubing for the tower.  The guy lines are fine stainless steel cable (fishing leader material).  I used the 3D printer to make the parts I needed at all the tubing transitions.  The wire from the remote runs down the tube and then back up to the sensor.  I have a PVC union in the pole so I can get the sensor down for service/cleaning when needed.
The 5-in-1 met its demise on 1/14.  Got the Atlas up and running today.
https://www.wunderground.com/personal-weather-station/dashboard?ID=KINCARME30
« Last Edit: February 03, 2019, 11:20:57 AM by karlzemlin »
Offline daman
Re: My new Atlas install
« Reply #1 on: February 03, 2019, 01:25:57 PM »
Very nice, the pole don't look level tho?
KMIBADAX38
AcuRite Iris/AcuRite Access
Offline karlzemlin
« Reply #2 on: February 03, 2019, 02:35:18 PM »
You must have missed where I said I'm a mechanical engineer.  The pole is quite plumb, thank you very much   :-P  Blame the photographer for not holding the camera straight while standing on the roof.
btw - how do you get the wunderground stamp to show up in the signature.  I tried dropping the code straight from the widget page and that didn't work.
Offline worachj
  • Twin Cities, Minnesota
« Reply #3 on: February 03, 2019, 04:31:06 PM »
[url=https://www.wunderground.com/personal-weather-station/dashboard?ID=KINCARME30][img]http://banners.wunderground.com/cgi-bin/banner/ban/wxBanner?bannertype=wxstnsticker_both&weatherstationcount=KINCARME30[/img][/url]
AcuRite Atlas
KMNSAINT173
Offline karlzemlin
« Reply #4 on: February 03, 2019, 04:41:06 PM »
Offline daman
« Reply #5 on: February 04, 2019, 09:26:20 AM »
I'm quite aware of your occupation you made sure people were aware of it, even the smartest people make mistakes  ;). Anyway nice install.
KMIBADAX38
