Dear all,
We have updated the WS View App to support our wifi weather stations to upload all sensors data(including the indoor sensors) to our free weather server:
https://www.ecowitt.net.
The supported wifi weather stations are:
HP3501 TFT Wifi Weather Station:
https://bit.ly/2Ug8T9OWH2320 LCD Wifi Weather Station:
https://bit.ly/2RiZCvHWH2910 Color Display Wifi Weather Station:
https://bit.ly/2KQhqvVHP2551 Large TFT Wifi Weather Station:
https://bit.ly/2D4K7UOHP3500 TFT Color Weather Station:
https://bit.ly/2DjA6UUThe operation is also very simple:
1. Go to your phone's app store to download or update the latest WS View app.
2. Click your device on the Device List of the app and update the wifi firmware to V1.3.2.
3. After the updating, click your device again to enter the ecoiwtt.net uploading page.
4. On the ecowitt.net uploading page, enable the ON button(displayed blue) and set the uploading interval time.
5. Copy the MAC address(will be used to add the device on the server later)
6. Press Save on the page.
7. Press Register at ecowitt.net and finish the registration on the page.
8. Press the upper left menu button and select Devices.
9. Press Add Device and input all the information needed.
10. Press Save.
11.Press Dashboard on the menu. Your sensor data would be available on the dashboard within several minutes.
Note: When select device address on map, please wait till the map display before select your address.
You may add a shortcut of the ecowitt.net website on the home page of your phone for quick access.
Note: If you have added optional sensors, such as WH51 soil moisture sensor, WH41 PM2.5 sensor, WH31 Multi-channel temp & humidity sensor to the above weather stations, you'll need to update the firmware(pending) of the console to ensure all the optional sensors data can be accepted by the ecowitt.net.
We'll let you know the new firmware for each weather station is available.
Note: The IOS version is under review now and will be available soon.
Any question, please let us know.
Best Regards,
Lucy from ecowitt
