Author Topic: WH3000 ERROR  (Read 115 times)
Offline novicamiric
WH3000 ERROR
« on: January 12, 2019, 04:23:52 AM »
Hi All, I need help with Froggit WH3000 weather station, station  is reporting 60 degrees Celsius outdoor temperature constantly, and its doing it after changed outdoor temperature sensor. Please see attached pictures. Pic 1- Reporting, Humidity is ok, Temp is Wrong??? Pic 2 - NEW Sensor, Pic 3 Station. Pic 4 Old Sensor
Re: WH3000 ERROR
« Reply #1 on: January 12, 2019, 06:10:34 AM »
Maybe the problem is that you didn't use an SHT30 or SHT31 as a replacement sensor. The original for your station is the SHT30. But the SHT31 should work. The SHT21 is prior generation stuff that may be different enough to cause problems is a guess.
WS-2000 | WS-2902A | ObserverIP | WeatherBridge (Meteobridge)
Offline novicamiric
Re: WH3000 ERROR
« Reply #2 on: January 12, 2019, 03:12:20 PM »
Thanks, i will order sht31 and try with that chip...
