Author Topic: Cumulus and Weathercloud  (Read 1398 times)
Offline Bernie1006
« on: January 08, 2019, 05:14:27 PM »
Hello all,
Looking for some help, I switched to Cumulus 1.9.4 build 1099 and trashed Weatherlink today and found it will upload to Weathercloud. I done the setup and made a initial connection to Weathercloud but it does not update past the initial connection... Any suggestions?
https://app.weathercloud.net/d0057819529#current
Bernie
Offline PaulMy
Re: Cumulus and Weathercloud
« Reply #1 on: January 08, 2019, 05:34:14 PM »
CumulusMX has it as a built in option, and for Cumulus 1 this may be helpful https://cumulus.hosiene.co.uk/viewtopic.php?f=4&t=16995&p=130770&hilit=weathercloud#p130770
Enjoy,
Offline Bernie1006
« Reply #2 on: January 08, 2019, 05:39:08 PM »
I will give this a try
« Reply #3 on: January 08, 2019, 05:42:49 PM »
Just checked. Your link updated a minute ago.
Offline Bernie1006
« Reply #4 on: January 08, 2019, 06:04:04 PM »
Yup Just noticed that after I followed the instructions in the link above... \:D/
Offline Bernie1006
« Reply #5 on: January 08, 2019, 06:36:52 PM »
Well maybe I was dancing a little to soon, It done 2 10 minute updates and stopped again!
Offline PaulMy
« Reply #6 on: January 08, 2019, 10:00:51 PM »
I presume you are running the \cumulus-weathercloud\weathercloud.exe program that is needed for Cumulus 1, and have followed the instructions in readme.txt
Is the ..\cumulus-weathercloud\weathercloud_realtime.txt being updated at your set interval?
Also is ..\cumulus_weathercloud\weathercloud_realtime_template.txttmp being created/replaced at each processing interval?
Is there anything in ..\cumulus_weathercloud\WaetherCloudLogger-log.txt that would indicate success or error?
Enjoy,
Offline Bernie1006
« Reply #7 on: January 09, 2019, 05:11:19 AM »
Where do I find this information? I can tell you I tried to locate the \cumulus_weathercloud\WaetherCloudLogger-log.txt with no luck. I would of assumed it would of been in the cumulis weathercloud folder but no.
Bernie
Offline PaulMy
« Reply #8 on: January 09, 2019, 10:44:27 AM »
In my case these files are all in the Cumulus sub folder where weathercloud is installed C:\Cumulus\Cumulus-add_ons\cumulus-weathercloud\
p.s. I had a typo in "Is there anything in ..\cumulus_weathercloud\WaetherCloudLogger-log.txt that would indicate success or error?"
and SB "Is there anything in ..\cumulus_weathercloud\WeatherCloudLogger-log.txt that would indicate success or error?"
Enjoy,
« Last Edit: January 09, 2019, 11:13:40 AM by PaulMy »
Offline Bernie1006
« Reply #9 on: January 09, 2019, 10:48:14 AM »
Ok I will try this when I get home from work...strange that it updated twice then failed
Offline PaulMy
« Reply #10 on: January 09, 2019, 10:52:31 AM »
Do you actually have the weathercloud.exe program running 24/7?
Enjoy,
Offline Bernie1006
« Reply #11 on: January 09, 2019, 10:59:29 AM »
Okay now I am confused.... Not surprised thought lol.... weathercloud is a program that has to run separately? When I was using Weatherlink.com to feed weathercloud nothing else had to run.
Offline PaulMy
« Reply #12 on: January 09, 2019, 11:12:20 AM »
For Cumulus 1 it was not built-in the program (I think this version stopped new development before WeatherCloud existed).  For the later developed CumulusMX it is built in like in Weatherlink and others.
A third-party module was created to have Cumulus 1 upload to WeatherCloud  see https://cumulus.hosiene.co.uk/viewtopic.php?f=4&t=11998&p=103927&hilit=weathercloud#p104663
Enjoy,
